Dash pop up box
BoostedAWD91
Danville,Pa
just saw this on ebay and thought it was quite interesting. I didnt know such a thing existed and exactly in the dash does it go? ebay
Boostdtalon
Buckley, Wa.
this goes in the middle of the dash where the # plate is
I was just about to ask where that mounts. I was thinking it went in front of the shifter. Cool little JDM bling.
belize1334
Bozeman, MT
I could see that working out very well for some kind of on-board logger display. You could have an LCD display about the size of an SAFC that is prone when the lid is down and then swings up into view when the lid opens.
BoostedAWD91
Danville,Pa
thanks for the picture. I really like that, but im sure ud have to cut the dash to get it to fit and would have to remove the badge
maroonmetallic
central WI
Ive seen these installed in a JDM clip.
You're correct about cutting the dash.
If installing it properly, the whole flat "base in front of our badge needs to be removed.
Once that is cut out, there "should" be holes in the plastic bracing of the dash to install this into.
Regards,
-Shawn
misterfixit
Midlands, UK
The cutout is exactly the same as the GSR supension pod cutout.
Rich
