CHASIS codes
G
zompton
What are the chassis codes i'm missing here?
1990 galant Gsx ja3cx56rxlz011419 (e38a)
1990 galant Ls ja3cr56v7lz018190 (e33a)
1991 galant gsr ?
1993 galant Es ja3ch56d5pz013263 (e33a)
1991 mirage hatch (1.5l 12v sohc) ja3cu24a9mu006506 (c52a)
1989 mirage hatch (1.6l 16v dohc) turbo ja3cu54z9ku027781 (c53a)
1989 cyborg hatch awd (1.6l 16v dohc) turbo (c83a)
FlyingEagle
THE Ottawa
OTOH not definitive, covering the C50/60/70/80 series of cars:
C52a Hatch 1.5 SOHC NA
C53a Hatch 1.6 DOHC Turbo in many areas, non-turbo in Europe
C58a Hatch 1.8 DOHC NA
C62a Sedan 1.5 SOHC NA
C63a Sedan 1.6 DOHC NA - Lilevo type? Also Eagle GS type
C69a Sedan Europe with a 4g93 DOHC, possibly the bubbled rear window
C73a Much like the Eterna version of a Galant, this is the Eterna rear window version of the Mirage 4 door sedan
C83a 4WD non turbo hatch just like the c53a, but with a solid rear axle and matching AWD drivetrain
These are screen shots from ASA, and you can tell the region/type of ASA in the top left hand of each left side window:
G
zompton
I should have specified. I'm looking for usdm chassis codes. So i filled in two of them, thanks for the help. Just need one more! Out of curiosity what is the chassis code for the mirage cyborg?
fuel
Toronto, ON, Canada
E31A = 1.6L 4G32 SOHC FWD
E32A = 1.8L 4G37 SOHC FWD
E33A = 2.0L 4G63 (either DOHC or SOHC) FWD
E34A = 1.8L 4D65 SOHC diesel turbo FWD
E35A = 1.8L 4G67 DOHC FWD
E37A = 1.8L 4G37 SOHC 4WD no 4WS
E38A = 2.0L 4G63 DOHC 4WD no 4WS (can be either non-turbo GSX or turbo RS)
E39A = 2.0L 4G63 DOHC 4WD with 4WS (cam be either turbo VR-4 or non-turbo MX-4/VZ-4 etc)
Also 'Cyborg' can refer to both the C50/60/70/80 88-92 shape Mirage as well as the CA 91-95 shape
With the C50/60/70/80 3rd gen Cyborg denotes the top of the range models for both the N/A and turbo variants in both FWD or 4WD. So there are technically two chassis codes alone in the 3rd gen Mirage a Cyborg could be.
In the 4th gen Cyborg is only the MIVEC CA4A model, same with the 5th gen with the CJ4A model.
the wiseman has spoken /ubbthreads/images/graemlins/worthy.gif /ubbthreads/images/graemlins/worthy.gif /ubbthreads/images/graemlins/worthy.gif
G
zompton
Ok so I need 88' cyborg, awd turbo.
G
zompton
So i'm missing the a galant gsr and ls.
