bazeng
Hey guys
Just thought I'd share my progress with the VR4.
Its been good and bad, lots of money and time spent on the car.
Currently 3 years in the build, trying to do as much as possible myself its finally near completion. Over the 3 years I've had it running in N/A (run in motor), in that form it made around 120kw's (160hp) at the front wheels.
After bolting on the manifold / turbo it made 300kw's (400hp) at the front wheels. The fuel system was not holding up, it was leaning out up top and also had some spark issues. The main problem with the turbonetics t3 manifold was the boost creep issue. It would start at 14psi bar and rise to 28psi (3000rpm - 7000rpm).. no way to fix it at all...
I drove it around in this stage for about 2 weeks before pulling it down again.
An attempt down the 1/4 led to HEAPS of wheels spin and 2 broken driveshafts..
Deciding that the suspension needed work, i purchased a set of HOTBITS race coilovers and went for a new manifold. The manifold is a custom piece and has been ceramic coated. The turbo also has been ceramic coated.
The inlet manifold is off to get extrude honed and the t/b bored out from 64mm to 68mm.
The old fuel system consisted of -6 braided lines, walbro 255 and 780cc PTE injectors
the new fuel system no consists of -8 braided / tube lines, bosch -044 and sard 800cc injectors.
Anyways, here are some pictures.
feedback welcome!
Old turbo setup
New turbo setup
Collector of new manifold
Davies Craig electric water pump
Revised fuel system
Sparco Race seats
Hotbits Race coil overs with NOLTEC camber tops
Custom radiator
Alternator relocation
Stock brakes (twin pots) VS Big brakes (made only possible with some guys on this board)
Thanks for looking guys
feedback welcome!
Old turbo setup
New turbo setup
Revised fuel system
Sparco Race seats
Custom radiator
