anyone bought this ebay o2?
my buddy had one.. there not to bad...beats the stock o2. I have a jmf o2 and man spool up is nice with one vs a stock cast part.
Andy_S
Shithole Wisconsin
I have one. Haven't had a chance to run it, but it looks pretty nice. Needs a little clean up with a grinder because the workmanship isn't what you would find elsewhere. Other than that, it looks like a decent quality piece.
Terry Posten
Davenport, Iowa USA
Just my 2cents.
The O2 bung is not good for a WB O2 setup but OK for a stock sensor.
The turbo side gasket is not what I would use for this setup. It looks like (from the pictures) that it is a thick "fiber" gasket and I would only use the steel flat gasket. The fiber style wont hold up under the strain of our setups and would keep allowing the bolts to loosen up.
Other than that, if the exhaust flange is set so that you can use a "stock" replacement downpipe w/o any modifications, the part should work OK.
Andy_S
Shithole Wisconsin
^ That reminds me. I forgot to mention that the gaskets and hardware aren't worth the materials they are made of. The bolts they came with aren't even the right thread pitch. Like mentioned, I would use different gaskets.
pachood_1953
eau claire, wi
Yeah, I'v had the dump, and the recirculating housings. As already mentioned, they just need to be cleaned up a little bit, and the gaskets shouldnt be used.
For $65 (compared to 250+) I think they are very nice..I wouldnt hesitate to use it if your on a tight budget like I am.
I believe these are the same ones beaner (from here) sells. Thats where I bought my first one.
Polish
NE, IN
I had one on the 94 Talon I had last year, it was on when I got the car but it never gave me an issue. It was internally dumped but that was the best sounding DSMs I've had.
StarionESIR
Scranton, PA
I had also bought one from Beaner. When I was cleaning it up a little, I accidentally grinded thru one of the welds. /ubbthreads/images/graemlins/banghead.gif No more than 2 hours later I sold it to a guy locally for 40 bucks. I got one on my Colt too, but also hadnt had the chance to run it yet.
-Mike
