AFPR leaking fuel
vtecds1
Las Begas
While taking off the vacuum line, I found small amount of fuel dribbling out. Not a lot, but tear drop size every couple of seconds. I was wondering if anyone ever had the same problem or is it normal. It`s a Fuel Lab 515.
TylerAdamson
Iowa City, Iowa
Could you be more specific, where is the fuel leaking out of? Is it leaking out of the vacuum nipple, feed line, or the return line?
vtecds1
Las Begas
Sorry, vacuum nipple. Would this cause my car to have idle surge? Currently my car has a hard time starting, I`m guessing this would be the cause of it. I know that the aftermarket afpr eventually bleeds off, but I never had a hard time starting the car until recently.
toybreaker
iconoclast
The frp diaphragm hsa most likely gotten a pinhole in it.
Thos may cause cause many problems, including your hard starting, as the fpr won;t be able to control the fuel pressure .
vtecds1
Las Begas
Just got off the phone with a CSR at Fuel Lab. Told him the situation and a new diaphragm will be sent out today...that`s what I call great service. Should be in by tomorrow or Monday. Now, on to the next problem. /ubbthreads/images/graemlins/grin.gif
vtecds1
Las Begas
Quoting toybreaker:
I really hope it is causing my idle and hard starting problem. I have taken my throttle body apart 4 times now, and I've been messing around with the IPS, TPS, throttle cable and biss for about 2 weeks now.
jepherz
KC, Missouri
I remember Keydiver posting about this issue once. I can't remember which FPR he had the problem with, but I thought there was a design flaw in which one of the fittings was actually puncturing the diaphragm.
vtecds1
Las Begas
^^^I've been searching for the thread but can't seem to find it. I hope it's not the one that I got. But if it is, I guess they will be getting phone calls from me every time it leaks.
JNR
ca
It was an aeromotive and the vacuum fitting end('s threads) protruded too far beyond the wall of the housing, so he ended up having to shave it back (the fitting). I believe it was more of a freak occurence though, but I ended up doing the same to mine, just to be on the safe side...
Best bet is to PM him though, so you could get what happened or what he did straight from him...This was a few years ago I talked to him about it and unfortunately, nothing is saved here beyond a couple years ago, for the most part. He may chime in though, as calling out his name is akin to lighting the bat signal it seems (say it three times in the mirror for best effect tho) /ubbthreads/images/graemlins/grin.gif
vtecds1
Las Begas
Problem solved. The diaphragm came in Monday and it took about 15mins to swap them out.I couldn't see any holes on the old one but I don't see any more leaks after the install. Idle is perfect. Thanks fellas and props to FL for the warranty service.
