aem 3 bolt cam gear?
tektic
ronkonkoma, ny
I have this set of gears. They are about 10mm thicker than the stock gear. I need a longer bolt but couldn't find one with a built-in washer. Would a regular lock washer throw off the balance of the cam?
Anyone local that has degree tools and can help me zero out my gsc s1 cams ?
I may just say screw these gears and run stock.
EHmotorsports
Beaverton
Don't use a lock washer. Use a light locktight.
EHmotorsports
Beaverton
I would use at least a grade 8 alen head bolt with a flat washer. Black type.
tektic
ronkonkoma, ny
The stock bolts have that flower pedal shape to them which I figured was for locking. I originally bought spring washers which are very thin lock, just tough to get centered. The bolt and washer were both grade 8.
