JamesFoster
So I picked up number 852/2000 a few months ago, with a handful of issues, my goal has been to fix every one of those issues while making the car a reliable daily driver and also increase performance. When I picked up the car, it leaked oil, trans fluid and the transfer case leaked from the yoke, had fluid spewed all over the underbody and exhaust. The driver cv boot was torn, the valve cover leaked, and the cam angle sensor was going out. Also the front mount was way too big for the setup and was not mounted properly, and the piping was ill fitted and rubbing on the power steering pump.
I spent the past few weeks fixing every one of these issues, first off was replacing the fmic with a universal unit. The new intercooler had no mounting points, so I went to my buddies shop and he fab'd up some mounts for me, along with redoing the intercooler piping. The following pictures show the progress of that.
After that, I replaced the front left axle, pulled the transfer case and pulled the 5th gear cover off the trans, removed the output shaft, and replaced the output shaft seal, that is where the trans fluid leak came from.
Then I took off the oil pan, cleaned it up, and replaced it with the proper gasket materiel, import specific permatex stuff from napa. I also took off the valve cover and put a temp valve cover on until I get the Mitsubishi one powdercoated. Then I removed the pcv valve and put a hose barb with a line to the catch can to relieve crankcase pressure, and replaced the CAS.
Before putting everything back together, I removed the driveshaft yoke, RTV'd the inside of the yoke, and JB welded the outside to ensure it will not leak again.
New gaskets, Redline MT90 in the trans, and Heavyweight shockproof in the transfer case.
oil pan cleaned up and ready to go
BC 272's
And the most recent addition, A-pillar pod riveted in, with AEM Tru Boost and UEGO Wideband.
And now I'm happy to say the car has no leaks and runs great! More to come soon though...
Edit: Just for my own sake so I have it written down somewhere, I forgot to mention that I also replaced the ECU with one with the caps replaced and I replaced the ISC motor, and put in a new 140 amp rebuilt alternator with 4 gauge power and ground wires.
BC 272's
