1mm O/S valves
Galantvr41062
plymouth, MN
I think most high HP builds, 600+ AWHP have 1mm over intake and exhaust valves. Just putting in 1mm over valves with no machine work to the head will hurt flow, and HP/torque. But if the valve seats are cut to fit over sized valves and the port work is matched and your setup will support it I think its a good idea.
~John
Steve885
Concord ca
Sorry should of explained my self..I'm in the process of replacing all valves due to a timing misshap..the heads going to the machine shop Monday. Just thinking of how I could put every dollar I have into this f#%*ing car
Galantvr41062
plymouth, MN
what is the current setup? future plans/goals for the car. I know a lot of people my self included that has gone plenty fast and made good power with stock valves.
TomN
North Port, Fl
If your replacing the valves anyways then yes have 1mm over put in.
5OF2k
colorado springs, colorado
You dont need OS valves, at all. Keep the stock sized valves and go flatfaced if you want a benefit in power. Also, be sure the machine shop grinds the seats and faces at 5angles and for a turbo setup. Ive seen machine shops grind the faces of turbo valves to NA spec, and you'll burn right through the valves.
As a for instance, my old built head from one of my last Talons is now on my friends car. By built, i mean crower springs/retainers and flat faced factory-spec cut valves BTW. Anyway, his car makes 790AWHP at 40psi on a bigass BW snail.
Oversized valves are not necessary, and could actually decrease efficiency dependant on setup, especially for a street car. The heads on these cars are capable of handling a lot of airflow from the factory. A LOT.
-Jake
-Jake
