1g to 2g
so i know the suspention doesnt wotk will a 2g trans work with a 1g "gvr4"
thanks for yout time -dave
No it will not. You will need to find a first gen tanny and if it's a 90 you have swap the shifter and linkage I beleive.. If you are looking for one try Gary at Mitsubishi graveyard thats where I got mine.. /ubbthreads/images/graemlins/smile.gif Great price and rebuilt..
Barnes
Richland, WA
They don't? I could have sworn they did. Just have to get a different starter plate. Anyone got confirmation either way? /ubbthreads/images/graemlins/dunno.gif
belize1334
Bozeman, MT
I believe there is some issue where the 2Gs had two transmission mounts and two engine mounts where a 1G has one transmission mount and three engine mounts. If I remember my reading correctly this is does not inhibit anything as you can still use the one transmission mount consistent with a 1G and then leave the other off entirely and run the three engine mounts. I've not done it myself but I know that there are 1Gs w/ 2G transmissions.
Polish
NE, IN
Quoting mac515:
No it will not.
Incorrect.
Here is a how-to from our very own forums on how to put a 2g trans into a GVR4.
Thank you, Come Again. /ubbthreads/images/graemlins/smile.gif
Myles
Skokie, IL
Quoting onesicstar:
Actually these are sixth generation Galants.
Gimpin
Plant City, FL
a 2g tranny will work in a 1g dsm / gvr4, but you might be better off selling the 2g tranny and buying a 1g one ... reason is 2G trannys are very desireable and are worth more than the 1g trannys because they are getting tough to find
you can put a 2g tranny in a 1g but not a 1g tranny in a 2g
sorry im new to the vr4 thing thanks for correcting me... thanks for the link to the how to install.so let me get this right cause i went to sean @full function and he said the casing was different..but im guessing its the whole 2 mount thing. so as long as i get the plate from the 2g it should bolt up to a 91 vr4.as far as the 22 or 23 spline i dont know how to check witch i have.how do i check?when i bought the car the guy said it has a jdm trans with the usdm transfer case he said it worked fine.i got the car in peices so yea.. and as far as gettting the 2 g trans i can get a shept racing trans cheap so i figure its gonna hold the power better.. thanks for all the help guys -dave
Hertz
Chicago, IL
How do you check? You pull it out and count them. /ubbthreads/images/graemlins/cool.gif
thats what i figured but wasent sure if their was some crazy way to tell thanks for the info
