1992 Galant VR4 Engine Problems
Need Help engine problem its not going its getting fuel air and spark but not firing
Please Help or any ideas on why its not going please help
/ubbthreads/images/graemlins/banghead.gif
You may want to re-read your above post to make sure it's grammatically correct. You stated a double negative, which may affect how a potential solution is proposed. Did the car run recently, and this problem occured abruptly?
-Alan C.
fivestardsm
Middle, Michigan
Possibly jumped time. Or you lost compression due to a headgasket blow out. Or maybe the rings are just shot. Need some more info. Was it running, have you done the t-belt on it? how many miles are on the t-belt? Were you driving it when it all of a sudden stopped?
Help us help you.
It was going
went to start it it wound over thought it was out of fuel
put fuel in it and still didn't start
its getting Fuel, air and spark
Please HELP
Read the posts above your last one and answer the questions so you can recieve the requested help.
+1 to fivestar's post.
