15's on the Galant
Terrance362
Winston-Salem, NC
What's up? I wanted to run Rota Sliptstreams on the ol galant. There isn't any clearance issues is it with stock brakes is it? I wanted to run 15x7. Any input will help. Thanks in advance
Terrance362
Winston-Salem, NC
That's what I said. I was telling a buddy I was gonna run them and he was saying they wouldn't work for some odd reason. Thanks man for the info/ubbthreads/images/graemlins/worthy.gif
fuel
Toronto, ON, Canada
it all comes down to the spoke design and offset. If the wheels are designed more for RWD cars with a lower offset, chances are the spokes are too close to the mounting face to clear the brake calipers. Slipstreams tend to be used on mostly FWD cars so you should be fine.
slugsgomoo
Tacoma, WA
A lot of it comes from FUD from DSM guys who are confused because their car came stock with 16s, so clearly that is what you need to clear the DSM "Big brakes". Of course, the fact that our cars came stock with the same brakes... /ubbthreads/images/graemlins/wink.gif
I am just glad MH is building a bias ply 17" tire now, because my brakes preclude my ability to run small wheels anymore /ubbthreads/images/graemlins/frown.gif
FlyingEagle
THE Ottawa
Quoting turbofonz:
Stock wheels are 15" I haven't seen a 15" that doesn't fit over stock sized brakes
I have wagon wheels ala Monte Carlo style, and although they have special in and outboard lips to make them super hubcentric, with the addition of machine rotor centers, my Colt is wearing Galant VR4 rotors, and Galant VR4 15" rims ... albeit with Wilwood 4 pot calipers under them, and just clearing by less height than a thin wheel weight takes up. In fact I had to move the weights in the outer portion of the barrel, just to get the wheels on without hearing a scraping, which also would have been worse when cornering.
So yeah, they fit, no problem.
belize1334
Bozeman, MT
Could also have clearance issues with the rear trailing arm. The backspace is reduced closer to the hub so wider wheels have to also be larger diameter or they'll interfere. Here's a good link for known combinations. click
Vince
Puget Sound, WA
The bad part about even considering 15" rims is that the size tire itself is being discontinued. All performance 15" tires have vanished except for a few remaining basic all season tires with dismal 'soccer mom' compounds.
I need tires, but have to look at bumping to 16s rims just to get a quality compound. Chasing after 15s is a waste of time and a loosing battle in the long run.
Vince
gvr4ever
central Indiana
You can still get a few 205.55.15 in performance catagory. Stock size seems to not have a single performance tire left.
I agree in the long run, 16s+ are the way to go. If you are looking to buy new wheels in the first place, don't bother with 15s.
I'll probably get one more set of 205.55.15s and deal with upgrading to 16s at a later date.
fuel
Toronto, ON, Canada
You can go 205/60 R15 too as an alternative. They used this size on a few performance cars (namely EvoII/III) and some good tyres are still available.
gvr4ever
central Indiana
Good to know on the 205.60.15
Just looked on tire rack and they had one track tire in that size. They currently have 3 options in the summer performance category for 205.55.15.
Didn't check other tire sources. Options are limited, but they at least still exist.
Vince
Puget Sound, WA
Agreed, and good to know, as I was looking at OEM sizes. Probably should buy a set soon before they disappear!
Still unfortunate that none of the available compounds are a match to what I run on all other (and past) cars, but they are certainly better than basic All Seasons!
Thanks!
idreamidrive
Murray, KY
Quoting Vince:
That statement is not even remotely true. 15" tires are still golden due to all the E30 BMWs, miatas, and other 80s/90s racing car series/autox. You just need to get 205/50/15 or 225/45/15 which isn't the correct size for us to spin the odometer correctly.
16" are pretty much dead.
17"+ has a ton of options.
belize1334
Bozeman, MT
IMO, 205/50/15 and 225/45/15 are too small for these cars. By contrast, 205/55/16 and 225/50/16 are both excellent sizes and a quick search on TireRack will return many good options across all performance categories. The problem with 16's is not the tires, it's the wheels; finding a AWD compatible offset in anything wider than 16x7 is very difficult.
As William mentioned 205/55/15s above, that size is the best match in overall diameter tire staying with the 15 inch size. 205/50/16 is very close if going up a diameter.
I had a set of 205/50/15 on one of my GVR4s when I bought it, and they looked stupidly small.
I may have a set of new tires in the 55 size available if someone wants them. I got them last year with some wheels I bought, but I may not use them. I will check the brand and model and verify the size.
