Galant VR-4 Forums » Galant VR-4 » Newbies » +35 offset wheels
+35 offset wheels
Tre3zy
correct me if im rite...Wyldcarz been rolling hard for a long time
637/2000
Galant VR-4 org Post #: 823671 posted 08/25/09 04:02 AM     Remind Me!  Send Private Message   Edit Post
just wondering if anyone here have a +35 offset wheels on your vr4... if you guys do you have any pics???? im planning on putting a +35 17x7.7 or 17x8 wheels on my.... will the offset be too much or not???? thnx guys
GARAGE BUILT
#ZukiFab / Tuned
Build Thread:
Current Personal Best 11.75 @ 119
Posts: 601 | From: South San Francisco, CA | Member Since: 11/25/08 | IP: (67.170.205.152) | Report this post to a Moderator
iLLeffeKt vr-4
Hertz pulverized mine
1759/2000
Galant VR-4 org Post #: 823674 posted 08/25/09 06:04 AM     Remind Me!  Send Private Message   Edit Post
17x8 with 35mm offset will stick out a bit in the front.
17x7.7? You mean 17x7.5 right?
Here are some pics of my car when I had 17x8 35mm offset rims with 245/40-17 tires:
Adrian
1759/2000 Summit White Sold
1991 Eclipse GS-X Sold
2013 EVO X MR - Daily
Edited by iLLeffeKt vr-4 (08/25/09 07:34 AM)
Posts: 2153 | From: NYC | Member Since: 07/26/04 | IP: (208.54.87.66) | Report this post to a Moderator
mj_rosenfeld
Galant VR-4 org Post #: 823675 posted 08/25/09 06:06 AM     Remind Me!  Send Private Message   Edit Post
You want 38 to 45 mm with an 8-inch rim width. The 35 mm is fine for clearance on the back side but it will stick out slightly.
Mike R.
Edited by mj_rosenfeld (08/25/09 06:09 AM)
| | | IP: (70.61.245.75) | Report this post to a Moderator
Tre3zy
637/2000
Galant VR-4 org Post #: 823850 posted 08/25/09 03:39 PM     Remind Me!  Send Private Message   Edit Post
Quoting iLLeffeKt vr-4:
yea ive notice how it is sticking out a bit in the front.... but not too bad though.... it looks clean.... anyways does it rub on the front when you go thru big bumps or not????
GARAGE BUILT
#ZukiFab / Tuned
Build Thread:
Hard Snarker
1051/2000
Galant VR-4 org Post #: 823874 posted 08/25/09 05:05 PM     Remind Me!  Send Private Message   Edit Post
If you camber in the front they won't stick out at all. Click the link in my sig to see what my 17x8's look like. I run negative 2.3 degrees camber p front.
I'd post pics directly, but I'm on my phone which makes that a pain in the ass.
-Mark
1051
Posts: 11891 | From: Yakima, WA | Member Since: 04/29/01 | IP: (206.53.157.53) | Report this post to a Moderator
iLLeffeKt vr-4
1759/2000
Galant VR-4 org Post #: 823903 posted 08/25/09 07:03 PM     Remind Me!  Send Private Message   Edit Post
My setup never rubbed however I was running HotBits coilovers which are considerably stiffer than the stock vr4 suspension. But even driving through the pot hole infested NYC it never rubbed.
At the time I was running about -.5* of camber. I'm sure with -2* or more it would of tucked in nicely just like Turbowop's car.
Adrian
Posts: 2153 | From: NYC | Member Since: 07/26/04 | IP: (74.68.130.12) | Report this post to a Moderator
Hard Snarker
1051/2000
Galant VR-4 org Post #: 823935 posted 08/25/09 08:27 PM     Remind Me!  Send Private Message   Edit Post
Some of the pics in my member's ride section are with less camber and dont' tuck completely. I added more camber a few weeks ago.
Here is a better shot of the current front camber:
-Mark
1051
Edited by turbowop (08/25/09 08:29 PM)
Posts: 11891 | From: Yakima, WA | Member Since: 04/29/01 | IP: (97.90.49.2) | Report this post to a Moderator
Tre3zy
637/2000
Galant VR-4 org Post #: 824030 posted 08/26/09 01:53 AM     Remind Me!  Send Private Message   Edit Post
nice turbowops car is the kind of setup im looking for.... my bad bro if im trying to copy "drop" and "look" of your car.... just that bronze or gold rims on a green vr4 looks really nice in my opinion.... my vr4 is green too and im planning on putting some gold rota torque on them or rota grids.... havent decided yet but once i do ill post up some pix on it....
GARAGE BUILT
#ZukiFab / Tuned
Build Thread:
bustedsm
trying to feel really special
Galant VR-4 org Post #: 825289 posted 08/30/09 10:37 PM     Remind Me!  Send Private Message   Edit Post
35mm offset I think
2006 Kawasaki ZX-6R 636 - Raw Plasma Candy Blue
Posts: 844 | From: Ripley, Tennessee | Member Since: 11/30/06 | IP: (70.246.205.217) | Report this post to a Moderator
Garfield Wright
Galant VR-4 org Post #: 825375 posted 08/31/09 10:18 AM     Remind Me!  Send Private Message   Edit Post
Evo 8-10 wheels are +38mm offset.
| | | IP: (75.249.219.152) | Report this post to a Moderator
Galant VR-4 org Post #: 825376 posted 08/31/09 10:22 AM     Remind Me!  Send Private Message   Edit Post
Quoting turbowop:
Mark,
Does running negative 2.3 camber create any uneven tyre wear issues?
Posts: 7315 | From: East Sussex, U.K. | Member Since: 04/19/04 | IP: (116.48.193.77) | Report this post to a Moderator
iLLeffeKt vr-4
1759/2000
Galant VR-4 org Post #: 825379 posted 08/31/09 10:29 AM     Remind Me!  Send Private Message   Edit Post
Negative camber will not kill the tires quickly if the toe is set to 0.
Adrian
Posts: 2153 | From: NYC | Member Since: 07/26/04 | IP: (38.105.174.65) | Report this post to a Moderator
Hard Snarker
1051/2000
Galant VR-4 org Post #: 825527 posted 08/31/09 08:05 PM     Remind Me!  Send Private Message   Edit Post
My tires wear out faster from dry rot than they do from negative camber since I don't put a whole lot of miles on the car. It's due for tire replacement now, and the damn things have tons of tread left. And as iLLeffeKt vr-4 mentioned, as long as the toe is set to zero, it's not a huge issue. Toe in/out is the real tire killer.
-Mark
1051
iLLeffeKt vr-4
1759/2000
Galant VR-4 org Post #: 825687 posted 09/01/09 10:55 AM     Remind Me!  Send Private Message   Edit Post
Drove with -4* of camber on my gsx for quite a while until I got the adjustable Ingalls arms. The tread was even all the way across. Toe was set at 0.
Adrian
Galant VR-4 org Post #: 827077 posted 09/06/09 09:45 AM     Remind Me!  Send Private Message   Edit Post
That's good to know, I think I can get away without flares in that case and just roll the fenders. Thanks.
Edited by cheekychimp (09/06/09 09:53 AM)
Posts: 7315 | From: East Sussex, U.K. | Member Since: 04/19/04 | IP: (218.250.62.209) | Report this post to a Moderator
Hard Snarker
1051/2000
Galant VR-4 org Post #: 827126 posted 09/06/09 01:23 PM     Remind Me!  Send Private Message   Edit Post
What size rubber are you running, Paul? Karter has 255's on his car using 17x8.5's and with some suspension work and camber got his to tuck under the fenders.
-Mark
1051
Galant VR-4 org Post #: 827129 posted 09/06/09 01:37 PM     Remind Me!  Send Private Message   Edit Post
Mark,
I'm not even running that wide. I'm pretty sure I have 245 on there. The rears tuck nicely but it is the fronts that sit proud. The problem I have right now is that I don't have adjustable strut/camber mounts on there. I have some now and I'll fit them and see if I can get the fronts to tuck as well. I need to check the offset too, I think it might be +38 on these rims.
Hard Snarker
1051/2000
Galant VR-4 org Post #: 827131 posted 09/06/09 01:45 PM     Remind Me!  Send Private Message   Edit Post
I have my Tein camber plates maxed out. That gave me a max negative camber of roughly -2 degrees. I used camber bolts on the upper hole of the lower strut mount to gain another -.3 degrees.
-Mark
1051
GVR-4
Creative Name Huh?
77/1000
Galant VR-4 org Post #: 827221 posted 09/06/09 09:40 PM     Remind Me!  Send Private Message   Edit Post
You probably don't drive your car enough to know this, Mark, but have you had any problems with the adjustable camber bolts moving on you?
Dave Peter
Can't polish a turd.
Posts: 2598 | From: Asheville, NC USA | Member Since: 04/22/02 | IP: (97.89.178.165) | Report this post to a Moderator
iLLeffeKt vr-4
1759/2000
Galant VR-4 org Post #: 827230 posted 09/06/09 10:09 PM     Remind Me!  Send Private Message   Edit Post
I ran adjustable camber bolts on the gsx and they didn't move. I even autoxed the car and they held up just ine, not to mention hitting countless potholes in nyc.
Adrian
Posts: 2153 | From: NYC | Member Since: 07/26/04 | IP: (208.54.94.21) | Report this post to a Moderator
Hard Snarker
1051/2000
Galant VR-4 org Post #: 827239 posted 09/06/09 10:20 PM     Remind Me!  Send Private Message   Edit Post
I've taken a couple of 2hr trips over the mountain pass to Seattle this summer and haven't had an issue with them yet.
-Mark
1051
kartorium
hillbilly racer
334/1000
Galant VR-4 org Post #: 827352 posted 09/07/09 01:17 PM     Remind Me!  Send Private Message   Edit Post
My camber bolts were moving initially, but I reinstalled them and now it seems to stay put. I must have just not torqued them proper or had the washer lined up wrong Pretty scary the first time it clunked out though
Posts: 2962 | From: ellensburg,wa | Member Since: 01/14/02 | IP: (96.41.213.15) | Report this post to a Moderator
Hard Snarker
1051/2000
Galant VR-4 org Post #: 827354 posted 09/07/09 01:24 PM     Remind Me!  Send Private Message   Edit Post
Hoping to not deal with issues on mine, I actually broke out the torque wrench for them.
-Mark
1051
GVR-4
Creative Name Huh?
77/1000
Galant VR-4 org Post #: 827387 posted 09/07/09 05:12 PM     Remind Me!  Send Private Message   Edit Post
What's the spec on them? I just hit them with the impact. I just bought a camber gage and with luck I hope to do an alignment this week. Too bad I don't have a level place of my own.
Dave Peter
Hard Snarker
1051/2000
Galant VR-4 org Post #: 827389 posted 09/07/09 05:21 PM     Remind Me!  Send Private Message   Edit Post
If I recall, the instructions said 55ft/lbs. This is for Ingall's brand camber bolts, others may differ.
-Mark
1051
Pages: 1 | 2
Generated in 0.118 seconds in which 0.076 seconds were spent on a total of 15 queries. Turbo powered.
