^ And also, no it wont help fuel cut. Fuel cut is imposed by the ECU when the MAF sees more air coming in than the car should reasonably be capable of handling in stock configuration. The only way around it is to socket and chip your ECU.
But I'm not convinced you're experiencing fuel cut.
Anyways I'm to retarded and can't hook up a boost gauge my stock boost sensor goes to full boost before I feel any boost at all
the best way I can describe the fuel cut is as soon as I start to actually feel the boost it makes a really loud slam(is why I feel bad every time I drive it) and stops boosting then cuts in and cuts out
Will a vpc help with fuel cut?
And one more how much to get ecu chipped and socketed
Not stock items (to my knowledge)
16g turbo 3 inch exhaust no cat...hks BOV (uncirculated)....custom front mount
....(suposedly forged pistons) and I think that's it
I'm on the hiway in 5th and can't go faster than 70 without building full boost(on stock gauge).
And if you try and go faster is starts to cut out and go slower then if you floor it ...the loud slam hits and is not fun
Also can't shift into second while going up a hill with out the car start to cut out(while the stock boost gauge is full)
And where would knock sensor be located any where I could check
And southcalivr4 told me it was fuel cut while he was driving the car( he seems preety smart bout these cars)
And why can't I uncirculate I've seen other cars that are uncirculated without my problems just wondering is there something u need to do if your gonna make uncirculated
You have to recirculate your BOV on a car with a MAS like ours. Unless you switch to a speed-density air metering system, you *really* need to recirculate your BOV.
Your air is being metered by the MAS as it gets sucked in towards the turbo. All of that air has to stay in the system, because the ECU has provided enough fuel for that much air. If you let any of it out, the ECU does not know this.
If you want to vent to atmosphere, we will kill you in the face. /ubbthreads/images/graemlins/grin.gif Or you have to switch to a different metering system which wont meter the air until it is actually headed to the TB such as a GM MAF in blow-thru configuration. Or a VPC I believe.
Quoting yeti:
Misfire is from plugs or wires right?
Yes, it is something ignition-related. When I had a misfire under heavy load it was the plug gapped too far.
GO to VFAQ.com and read, then read some more, then read it again just because.
Second do a boost leak test on the car to see if you have any. They can give the car the issues you are describing. Check the plugs and wires to makes sure they are in good condition and gapped correctly. Make sure the car has sufficient voltage and that the alt or battery are not dead or dying. Not enough voltage will lead to missing under boost. Check the knock sensor to make sure the goo is still in it. It is behind the motor under the inatek manifold.
You will also need to get a REAL boost guage. The stock gauges doesn't even read boost it only makes a guess at what boost is by looking at other parameters. If you are running more than stock boost (10psi or so) on stock injectors and fuel pump if could just be knocking and retarding timing a lot. This is bad beyond your current issues, it could kill your motor altogether.
Beofe you ask how to do some of these things read the VFAQ. Most of it will be spelled out with detailed pcitures. When you have done ALL of this repost back with your findings.
I've seen this problem many times in DSMs with ECUs trying to sh*t the bed. Try swapping in a known good ECU and take it for a ride.
Quoting yeti:
You are blowing off air that has already been counted. The fuel to accomodate this air is delivered, creating a very rich condition when said air does NOT reach the engine.
Cars that can (properly) run a bov to atmosphere are metering the air AFTER the bov.
And u said knock sensor is behind motor underneath intake manifold?
Will there be a picture in manual
