Great Resource
Lukefraizer
Fort Collins CO
Just was searching around for the specs of a 4g63 crank and found this great place has everything anyone needs to know about our car! Also I couldn't find the specs of the crank. I have been thinking about how to make my JE pistons work that I just put in the cylinder and use a different crank to get the stroker affect. Any help would be great. I have eagle connecting rods and JE 8.5:1 cylinders. Can I just add the 100 mm crank from a 4g64 and make it happen or would that be terrible? I need a bit of help! This is that great place though ----> click
You need special pistons designed for a stroker motor. If you have 2.0 pistons and 2.0 rods a stroker crank will try and push them through the head. Engine damage will result.
Rausch
Cleveland, OH
Wrist pin needs to be moved up 6mm IIRC. That is the difference at the piston anyways.
raptorWagon
Oak Harbor, WA
Quoting Lukefraizer:
Or you can go here and just download the FSMs
