yeti
So after fixing all the boost leaks (still not all of them the jpipe, idle adjustment screw. And probably the throttle body)
Anyways took it for a quik spin around the block a few times (after letting it warm)
I was hitting 30+ lbs of boost and then slamming I would boost for about 5 seconds and then hit what I think to be fuel cut.
Could the minor leaks be causing the overboost?
The car still stalls at stop with no throttle it has symptoms of the "Hot start"(where the idle is as low as possible enough To start shaking sh*t)
I had the link to it does anybody know which web page I'm talking about.
