I'm not sure if I want to sell it or not. Just looking to see if there would be any interest. It's 1192/2000 the body has 120,000 miles on it. All the performance parts have less than 10,000 miles on them. The car is in great condition. I'm just getting tired of messing with it. The car has some problems with it. When you rev it and left off. The car will die. When I bought the car I thought the transmission was messed up cause it would grind going into second so I bought a built transmission off a member on here named steveb. But it's doing the samething I thinks its the shifter cables. I have a brand new set I bought from jnz tuning. I have parts that will go with it like a aem wideband,catch can,new autometer boost gauge. I took some pics of the car today. But the sun was going down so there not the best. I will take better pics if needed. I tried to post pics but I couldn't. I will try and post them again later. I'm also interested in trades. Thanks for looking.
-17msr wheels with brand new falken tires
-all new calipers
-slotted and drilled rotors with new pads
-ss brake lines
-new lower ball joints
-2g Mas Air flow
-pte 32/55E Turbo
- intercooler piping with hks bov powder coated black
-valve cover is powdercoated black also
-Front Mount- Garrett Core, precision Cast end tanks
-2G ported TB elbow
-62mm TB
-Forrester Intake Manifold
-Phenolic Spacer between the intake manifold and head
-Slowboy racing ported head
-650cc injectors
-Walbro 255 fuel pump
-Ferra valves w/ titanium springs
-HKS 264's (exhaust and intake)
-AMS longblock
-Eagle rods
-Ross 8.5:1 pistons
-The crank was knife edged by AMS
-All new bearings on the bottom end
-Ported 2G exhaust manifold
-AMS downpipe
-2 o2 sensors
-Buscher 3" exhaust (no cat)
-Tuned with the SAFC2
-kyb shocks on ground control coilovers
-built trans
-stage 3 competion clutch
-ACT stage 3 flywheel
-Stock 3-bolt rearend
-Nrg steering wheel
-all new calipers
-ss brake lines
-2g Mas Air flow
-pte 32/55E Turbo
-2G ported TB elbow
-62mm TB
-650cc injectors
-AMS longblock
-Eagle rods
-Ross 8.5:1 pistons
-AMS downpipe
-2 o2 sensors
-built trans
-Nrg steering wheel
