dsm suspention on a vr4 ?
frank1
anaheim
is it a bolt on deal or are they different?
Are you referring to the shocks & springs? If so then yes. The 1g awd shock assembly is a bolt-on affair except the front springs will need to be cut by one coil if they are the stock 1g awd springs. If they are lowering springs they will not work well on the car as it would make the car sit too low.
ib4ugetbashed
fivestardsm
Middle, Michigan
I never had to cut a spring on min, but I do know that the back is a little weak. If you have anything in the trunk like a system, or your battery, you might rub the fender wells.
I have a GS that the backs were getting weak, and instead of getting new rear shocks and or springs, I just put DSM springs in the front so that it would level out. It worked awesome.
belize1334
Bozeman, MT
It's bolt on but it's not a perfect fit. The rear springs are a bit too short so you either have to cut the fronts to compensate or else find a way to lift the back a little. It's been suggested that you can use the 2G rear upper mount which is about an inch taller and that this will make the car ride level.
frank1
anaheim
Quoting Garfield Wright:
ib4ugetbashed
yes , shocks and springs the rear springs are lowers than front I would need to cut them even if they are lowering spings
If you don't mind mix-matching springs, you could use the dsm rear oem springs & the dsm front lowering springs. I think that would balance out the car so there'd be no cut springs.
belize1334
Bozeman, MT
Remember though, that dsm suspension isn't exactly an upgrade. The springs are a TINY bit stiffer, but not enough to make much difference and the shocks are just OEM shocks. So if your suspension is dead to the world and you've got a line on a DSM setup for CHEAP then fine...but don't get caught up in thinking that you're gonna have a nice tight ride when it's over.
656of1000
Phoenixville, PA
I just auto-crossed my car with totally stock, uncut dsm suspension. I totally did beter than I thought I would.
The back does sit low, but it's not enough to bother me.
This picture over-exaggerates the effect.
But in this picture, the car looks proportioned front to rear.
The car does sit lower than with the stock suspension. What do you guys think, 1" to 1.5" drop?
It's still worth doing though, as a cheap "upgrade"
The hunker is definitely less noticable with the summer rims on , sitting on that hill. Are those evo rims, painted black?
talon
Denham Springs, La
I've been under the impression they would be the same as the GVR4 springs.
Sense they are not, can somebody please point me to a good set of springs that are specifically for GVR's?
Sorry for hijacking thread.
belize1334
Bozeman, MT
TireRack.com sells H&R lowering springs for the GVR-4. If you search for "H&R" I'm sure you'll find lots of info.
That is what is on my car, sits very nice
656of1000
Phoenixville, PA
Quoting Dbossman:
They are 17" 2gb GSX wheels, powder coated black with a chrome lip. I think they look super on the car!
