Can't bleed my clutch
Diego
My master cylinder won't feed any fluid through the line to the slave. If I push on the fork and press the slave in it will get stiffer but the peddle is dead... any solutions?
toybreaker
iconoclast
I'll be headed up your way today.
Do you have an air compressor at your place?
I can bring my vacuum bleeder, and we can get this job done.
Diego
See you in a bit, now to get Justin up here for some fun...
Brunoboy
San Bruno,CA Home of SFO
isnt the master cylinder rod the cause if it doesnt move or not? adjust it first so that the bleeder opens or closes?
Diego
Had TB out here to look it over, upon inspection, the cylinder takes in air instead of pushing fluid out...
TB is looking for a master for me from one of his local friend.
