bolt for the o2
Brunoboy
San Bruno,CA Home of SFO
on the o2 housing it has three bolts and one stud, The new turbo I bought has no stud, is there a place to get one? or has anyone done it a different way? I need to get the car assembled so if anyone has ideas thatd be great. thanks
-Shane
Brunoboy
Does anyone know where to get a stud like this?
rdomeck
Indianapolis, In.
The stud does not have to have an unthreaded section in the middle. If you had a bolt with enough threads you could cut that head off and use it as a stud! The best way would be to find the right stud, but it sounds like your trying to get this together right now.
Brunoboy
the mani to turbo bolts share the same thread but i have no way of cutting it up. any other ideas?
Diego
Say F the stud and just buy some bolts at HomeDepot, I just did.
Brunoboy
i cant seem to fit the bolt in that small ass crevice.
rdomeck
Indianapolis, In.
You don't have a way of cutting a bolt? Hack saw? Put a nut on it first, cut the bolt and back the nut off to clean up the threads! I believe the stud thread pitch is 10X1.25 You will find the normal thread for a 10mm is 1.5 You can sometimes find the 1.25 at PepBoyz! Good luck and if you don't have a hack saw and a vise....Go buy one now!
Brunoboy
i will get to that, thanks very much for the suggestions.
