BC Coilovers
RedTwo
New Zealand
I brought some aluminium bolts and nuts. Got an engineer to weld them onto the bottom of the strut mount.
The rears? Well GTO arms have brackets built into them so I don't have that problem /ubbthreads/images/graemlins/laugh.gif
Cant BC fix this bracket problem there selves?
Brunoboy
San Bruno,CA Home of SFO
So for everyone wondering, The Coilovers were really straight forward. it took 2 weeks to get them and it was a bolt on affair. The Only thing I noticed about the rear bracket for the brakelines is that it needed to be flipped towards the back and installing my Evo Suspension SS Lines from Garfield made it easy to route and bolt on. I did have to bend the stock bracket slightly(when i say slightly, it was a very tiny bend on the stock bracket , not the coil).
unfortunately I cant take pics of the car on the ground since I have a Clutch Drag Issue thats keeping me from driving it. The car is still JSB so I have no idea how low it is aha. will report back as soon as it is on the floor.
-Shane
strokin4dr
Savannah, GA
My BCs showed up on Monday. Hoping to get a chance to install them by the end of the week. I too will post some pics afterward.
belize1334
Bozeman, MT
Now I'm confused. How are the Evo SS lines different from 1g/GVR4 lines?
Also, for anyone with a set in hand ready to install, would you please measure the front lower bolt holes? They're slotted to allow extra camber adjustment but it'd be useful to know exactly how wide top and bottom.
OMFGeofffff
Burnsville, MN
^^^^They are 1 piece. So instead of getting 6-8(i forget) lines you get 4.
Brunoboy
Quoting belize1334:
They are one piece and fully moveable. once the mounting holes on the brake lines are installed, i can pull the lines to the length i want wherever i need it. Also The fronts come with Camber Plates so no need for camber bolts.
-Shane
belize1334
Bozeman, MT
I'm aware that they have camber plates. I'm also aware that the holes are ALREADY slotted for additional camber. This is important since the plates only allow about 2* camber which is really not very much for race applications. I just want to know the extent of the slotting. I could take mine off and measure but I thought it would be easier for somebody who hasn't installed them yet.
As for the brake lines, did you need an adapter to make them compatible with the OEM rear caliper.
Brunoboy
oh i see what your saying, and nope, It bolts up just like it should.
-Shane
Brunoboy
Well when I got them, I had a two finger gap in the front, and a .5 finger gap in the rear.Seems like a lot of camber in the rear.
Brunoboy
thanks, ill get better pics soon, i have that clutch dragging problem so i cant drive it anywhere.
Brunoboy
</font><blockquote><font class="small">Quoting Luke:</font><hr />
</font><blockquote><font class="small">Quoting dmj:</font><hr />
Spring rates KG/mm 180 front 220 rear. based on manufacturer claims.
Those numbers are the spring length, not the spring rate...
The spring rates are 10kg/mm front and 8kg/mm rear.
Here's the info I got from google about this coilover:
•Spring Rates Front - 180L-10K
•Spring Rates Rear - 220L-8K
Bump, after looking it over again, the Box they came in and BC themselves put it 8k Front and 6k Rear. You CAN ask for a different setup since it is made to order. I have not put any miles on mine yet since im still fixing the drag problem but I turned mine up to 28 all around and the car is pretty stiff if pushing on it and pushing down on it. But yea, for reference again, 8k/6k is how they come unless asked for another setup.
-Shane
Brunoboy
Quoting belize1334:
Also to Clarify, the Brake lines are not FOR an Evo, its made for the Vr4/1g that use Evo Suspension.
-Shane
Tre3zy
South San Francisco, CA
just got done installing mine yesterday and finish with alignment today... here is how she sits... had to mildly roll the front fenders... but im pretty happy with them... just gotta play with the stiffness now to my liking for daily use... btw dont mind the quarter panel it will be fixed soon...
thedsmguy
Vancouver Washington
Holy crap you car looks a lot like mine. (with a little more damage)
I have those turn signals and very dumped. I'm so jealous of your coilovers!
Nice ride!
Brunoboy
Quoting Tre3zy:
Looks good , your welcome for helping with install.aha
Tre3zy
Quoting thedsmguy:
Nice ride!
thank you
Tre3zy
update guys... did my first auto-x event with the coilovers... handled very well i am very happy oh how the coilovers performed along with my 26mm rear sway bar...
