intercooler upgrade
ronkonkoma, ny
Next best bet is vrsf for 1g.
A core with inlet and outlet on the passanger side will make for the shortest rout and leave more room for everything on the belt side of the engine. It also elevates the need for the ic pipe to travel above the exhaust manifold.
Wookalar
Arizona USSA
True. He could be doing mild build and use a jdm rs intercooler.
But if going for big power ets, or build your own if you have the tools and tech know how.
Cherry Hill, NJ
300hp you can use a JDM intercooler or an evo8 intercooler and do a little bit of custom plumbing. its easy and really cheap to achieve your goal.
