still got me home tonight!
Yao
Denver, CO
This was the fuse I put on the fuel pump rewire, don't know what caused it, but I got home. Weird part is that when I turn the key to off, the car still runs, that's what got me to trouble shoot and found this.
/ubbthreads/images/graemlins/uhh.gif
Bet the wire was too small and got it hot. Either that or the pump pulled too much current and the fuse didn't pop. I have seen that happen.
Homemade rewire, or kit?
G
zompton
Chinese inline fuse. Or you swapped a fuse in that is too high for that gauge of wire.
Cherry Hill, NJ
like i said im not sure i could have 12g, i bought a kit from MAP or one of those companies. so whatever is supposed to be in there.
Yao
Denver, CO
Well, it's a home made kit, and I ran a super heavy duty relay with 12 gauge wire all the way until the fuel pump cover with 30amp, I didn't want to drill out the cover to run it all the way. I'll double check the ground, are you talking about the ground at the relay or the fuel pump assembly? It is a cheap china fuse, I've put in another inline fuse with 20amp that is a better one, so I am gonna drive on that and keep an eye on it. what would cause the pump to draw more amp? dirty fuel filter? low fuel?
Yao
Denver, CO
by the way, why would the car still run with key shut off? Let's assume the wire is fused together and the pump gets power constantly. But shouldn't the ECU shut off injectors when the key is pulled? or cut the ignition when the key is pulled? I don't understand this part...
Near Seattle, Washington
I had a buy bring me a GVR4 for diagnosis/repair once. Wouldn't start. Kept blowing fuses.
Fuel pump was rewired and the relay used had somehow shorted internally. Replaced relay, no more problem.
I would never run a 30A. That's why it burned up. I would rewire the whole thing with a high quality relay. Make sure the grounds are clean and you scrape down to bare metal at the ground. Also you should pull the pump out and run new power and ground wires straight to the pump.
The key issue sounds like an ignition switch fault, or a turbo timer. Also check the MPI main relay make sure it's clicking like it should.
Yao
Denver, CO
Okay, I'll try the suggestions, thanks!! Here is the weird part, when I turn the key off and pull the key out of ign., the radio went off, the ecu even clicked off too??!! I do have fuse at the MPI line and when checked, it was okay. I've replaced the fuse with better quality and 20amp, might reduce to 15amp and the car seems to shut off and start normally now.
