wen i turn my wipers either on high or low they go the same speed and the intermittent works and squirters work but only wen it all want to but y do they move the same speed on either high or low
^ I would like more information on this also. I have the same issue and I was going to change the motor but this multi-switch seems more logical. Any idea where these parts are located /ubbthreads/images/graemlins/banghead.gif?
i been messing around and came to think that the relay is ok and so is the switch i personaly think its the motor getting old does anyone know where to get a new one
the motor has three brushes inside. one is only used to advance the motor timing to give the higher speed (thats what the relay switches in). If the car is quite old I'd guess the brushes are crapped out.
thats what i figured but everyone i talked to says no because its like wen a fuel pump works wen it wants after u run it for a while it goes good but u stop its hard to get started
