Galant VR-4 Forums » Galant VR-4 » Newbies » Clutch Switch
Clutch Switch
ziggydb
Galant VR-4 org Post #: 918938 posted 07/29/10 05:51 PM     Remind Me!  Send Private Message   Edit Post
The plastic/rubber piece on the clutch lever crumbled. If you buy a new switch does it come with that piece? Thank you
Posts: 95 | From: toledo | Member Since: 12/24/05 | IP: (72.241.190.74) | Report this post to a Moderator
Justin
Galant VR-4 org Post #: 919016 posted 07/29/10 11:48 PM     Remind Me!  Send Private Message   Edit Post
Are you talking about the piece that pops into the pedal lever? If so go to Napa and look through their body hardware. There is a similar deal that they sell. If they look at you like your stupid tell them it is in the Balkamp line. I don't know for sure that it will work, but its going to be just off if it doesn't.
| | | IP: (68.171.231.22) | Report this post to a Moderator
JackbNimble
Member +
Galant VR-4 org Post #: 919027 posted 07/30/10 01:21 AM     Remind Me!  Send Private Message   Edit Post
I just stuck a small nut and bolt through there when mine rotted and fell out a few years back. Been fine since.
slugsgomoo: kurt cobain, lead singer of nirvana
slugsgomoo: ate a shotgun
Barnes: omnomnomnom
Posts: 274 | From: Youngwood, PA | Member Since: 02/23/09 | IP: (76.125.154.88) | Report this post to a Moderator
ziggydb
Galant VR-4 org Post #: 919052 posted 07/30/10 07:05 AM     Remind Me!  Send Private Message   Edit Post
Yea its the part on the lever. Ill have to just look around at napa or hardware store. Thanks for the good ideas.
belize1334
1334/2000
Galant VR-4 org Post #: 919119 posted 07/30/10 02:24 PM     Remind Me!  Send Private Message   Edit Post
Quoting JackbNimble:
Same here.
Roger B. Scott
'91 Belize Green
Posts: 3313 | From: Dundee, Scotland, UK | Member Since: 11/18/03 | IP: (63.193.18.21) | Report this post to a Moderator
JackbNimble
Member +
Galant VR-4 org Post #: 919370 posted 08/01/10 01:41 AM     Remind Me!  Send Private Message   Edit Post
It really makes me wonder why they would make that part out of rubber when they know it's gonna dry rot and when it does, it's going to stop the car from being able to turn on. Really pissed me off when it happened, considering I was in a huge line for the new Indiana Jones movie when it happened. The traffic behind me was pissed too haha.
Barnes: omnomnomnom
stevep
Fixes ECUs
Galant VR-4 org Post #: 919429 posted 08/01/10 02:23 PM     Remind Me!  Send Private Message   Edit Post
Quoting ziggydb:
As far as I can tell you have to order it by itself, it not part of the switch part number.
In typical Mitsubishi style there are two rubber stoppers on the clutch pedal, one for the CSS and one for the cruise switch. They have the same reference number in CAPS but different part numbers depending on the use.
One is MB004185 and is called the clutch pedal stopper and the other is also used on the brake pedal and is MD151298 brake pedal stopper. I think I just ordered a couple of each so I'd have the right ones and a few spares since before they crumble they usually get a hole worn in them causing the switch to stop working.
Posts: 412 | From: St. Charles, IL USA | Member Since: 10/23/04 | IP: (67.175.252.163) | Report this post to a Moderator
1 registered and 21 anonymous users are browsing this forum.
Generated in 0.061 seconds in which 0.047 seconds were spent on a total of 14 queries. Turbo powered.
