Problem: The car has trouble starting up on a cold start. she will crank and crank. it seems to help get her started when i do short starter bursts. once she shows interest i feather the air peddle. hot starts are not a problem. huge puff of white smoke seen on start up and clears up after minutes.
the car:
1991 vr4 bone stock.
450cc stock injectors
16g (havent confirmed if its big yet)
ECU is rebuilt by i believe ebay user: motoguys_garage. which i have tired it with my talon and this rebuild does a much better job(i was seeing rich conditions with the talon ecu). the talon stock ecu floods it even more =\ which doesnt make sense to me unless my talon ecu needs a rebuild but i dont have cold start issues on the talon...
not much to say, its stock.
items recently fixed/replaced:
fix idle surge (big win for me) used: terry's talon trouble shooting which worked out very, very well. (do everything /ubbthreads/images/graemlins/laugh.gif then fixed!)
replaced valve cover gasket (i didnt know some people use rocks or as hard as, to seal the valve cover)
chit i checked:
vacuum lines, cleaned and changed all TB sensors (checked and calibrated as needed) and gaskets, ECU is good.
i have changed to a whole other known working set of plugs and wires, same result.
coolant temp sensor has been checked with MMCD to confirm it isnt -59c. which i tested with a known bad sensor - it passed as expected bad of -59c while the other temp sensor reads 10-15c (it is currently 59c where i live at this time of day), cold and in sothern cal 92335. its not very hot here.
CAS has been changed to a "thought" to be good. MMCD reports warmed up advance of 0-1% @ 840-990RPM (this is after a CAS change and i didnt time it)
my thoughts on the problem:
the gas in the car is ~1 year old. before you start screaming like banishes, the fuel does burn without issue while running. however, i will refuel in a few days but i really doubt the problem will go away.
i hope i didnt miss anything, im off to bed. thanks galantvr4.com!
the car:
chit i checked:
