trans fluid swap = big improvement
mikus
Aurora IL
My transmission (TRE build w/ fairly low miles) was a real bitch to get in 1st sometimes, grinded a tad into 3rd once in a while, and was just overall notchy. No major issues - just disappointing performance for a specialty shop build.
Swapped out the fluid during axle change, from what I think was BG, to redline MTL with 1/2 pint of Royal Purple - and all symptoms cleared up! The best $40 I could have spent on the car to date (barring repairs)
Just wanted to put it out there for those who debate whether a fluid change may help. I sure didn't expect this much improvement. FWIW I'm not knocking BG, it's good stuff.
ercp98
northlake in illinois
can you be more specific on the what royal purple you used?
gear oil weight? i wonder if this will be a good addition to penzoil syncromesh?
I was told a 50/50 mix of Redline 50/50 mix of redline lightweight shock proof and mt90. An Redline heavy weight in the t-case and the rear diff.. This is what I'm going with for my tranny, T case and rearend.
ApexHunter
Marysville, WA
I also noticed an improvement, switching from BG to a mix of 2qts MT90/the rest MTL on a Jacks Trans rebuild.
mikus
Aurora IL
RP was 75-90. I only mixed vs. straight redline because
1) the same mix felt nice in my last vr4's stock gearbox, and
2) the taller RP quart didn't fit my fluids shelf and I was tired of knocking it over /ubbthreads/images/graemlins/cool.gif
