3 Bolt LSD fit our GVR4's?
JSchleim18
Long Island, NY
It Helps
But seriously, try to use the search function...not too hard: +3 +bolt +lsd
They will fit no problems but IIRC EDIT:BOTH of the axles is different for the LSD
jepherz
KC, Missouri
One of the half shafts IS different. Also, you have to deal with AWS if you still have it, as DSMs don't have it.
ls2gto
Nampa, ID
BOTH axles are different!!! Just did the swap in my VR4...
Make sure the Axles and LSD are in good shape... And if you want to keep the AWS you must press the bearing off the LSD and the open Diff and place the Bronze gear on the LSD.. Not hard, but if you dont have access to press the bearing you might have to take it to a rear end shop.. And if anyone tells you The bearing will come off with a couple of screw drivers, their lying!!!
cOmpressor
Bay Area, CA
Ya if you want to keep your stock rear steering and cut down on some of the work just swap the LSD carrier assembly from the 3-bolt into your housing. Like stated the bearings are hard to get off so be prepared to take it to a machine shop and have some tweaker do the work for ya.
What is different about the drivers side axle?
SleepinGVR4
Danville, Pennsylvania
It has an extra spline to engage the LSD. To be on the safe side just use both 3 bolt LSD axles.
I've done this to my car. I had a guy i know swap the 3 bolt LSD "guts" into the non LSD 3 bolt "body" of the GVR4's rear diff. So i could retain the AWS. I had it done for a $100 and had it reshimed and everything tightened back down. Works great.
jepherz
KC, Missouri
Bringing this back because I actually found from personal experience that you need BOTH LSD axles. The right one (passenger side) has an extra set of smaller splines to engage the LSD, and the left (driver's) side positions the dust sheild/seal about 1/4" outside of where it should be, so you risk oil leaks etc.
Everything I had ever read told me that the left axles were the same for LSD and non-LSD except for a few hints from Keydiver. But, he is right, they aren't the same.
Yes, thanks for the confirmation. I also highly recommend just buying a new bronze AWS drive gear and bearing for that side, as its easy to damage them while pressing them off the old diff and they aren't too pricey.
jepherz
KC, Missouri
Just for proof, here is a few pictures of the difference between the 3 bolt axles. Both are left axles, one is LSD and one is non-lsd (Stock):
LSD is the shorter one:
