Galant VR-4 Forums » Galant VR-4 » Newbies » fixing my a/c. have question
oneup
Galant VR-4 org Post #: 357279 posted 07/08/06 05:54 PM     Remind Me!  Send Private Message   Edit Post
Does anyone know what oil(lube) I have to use on o-rings when you putting a/c line back together?
tia.
| | | IP: (65.27.143.149) | Report this post to a Moderator
s_firestone
Ctrl-Alt-Boost
918/1000
Galant VR-4 org Post #: 357285 posted 07/08/06 06:34 PM     Remind Me!  Send Private Message   Edit Post
Whatever oil your putting in the system that is compatible with the refrigerant your going to charge the system with. If your using R12 then refrigerant grade mineral oil. If your using R134a then either Poly Alkyl Glycol(PAG) or Poly Ester (POE) oil. Its just to lube the rings so they will seal and not bind when you tighten.
You could probably use a little 3-in-1 oil as a substitute. You could also use air compressor oil or air-tool oil.
Stephen Firestone
1992 GVR4 #918 of 1K
Edited by s_firestone (07/08/06 06:35 PM)
Posts: 1610 | From: Park City, UT USA | Member Since: 06/27/02 | IP: (24.170.24.226) | Report this post to a Moderator
oneup
Galant VR-4 org Post #: 357286 posted 07/08/06 06:37 PM     Remind Me!  Send Private Message   Edit Post
thanks man.
where can I get it?
s_firestone
Ctrl-Alt-Boost
918/1000
Galant VR-4 org Post #: 357408 posted 07/09/06 10:54 AM     Remind Me!  Send Private Message   Edit Post
Refrigerant oil can be obtained from any auto parts store. Preferably someplace that sells to auto repair shops because they will have a better selection. 3-in-1 oil and/or air compressor/tool oil can be obtained at any hardware store and most grocery stores, Walmart, etc.
Just don't use detergent motor oil like what goes in our engine or anything like wd-40.
Stephen Firestone
keydiver
Galant VR-4 org Post #: 357656 posted 07/10/06 10:31 AM     Remind Me!  Send Private Message   Edit Post
I think I just used dielectric grease on my A/C O-rings.
| | | IP: (68.232.56.164) | Report this post to a Moderator
1 registered and 17 anonymous users are browsing this forum.
Generated in 0.052 seconds in which 0.046 seconds were spent on a total of 14 queries. Turbo powered.
