Hey guys, I'm in the middle of tidying up all the shortcuts that the previous owner has made and I noticed there's no circuit breaker or fuse for the battery relocated to the trunk, what sort of fuse rating is everyone using?
I love my crazy mother!!!
Posts: 1639 | From: Manchester, NH | Member Since: 07/17/06 | IP: (173.14.186.153) |
I have a similar one. Not sure the amperage, either 120 or 200.
91 VR4 855 Nile Black 92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10811 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) |
CutlassJim poop load of room 1799/2000 1788/2000 935/1000 912/1000
posted 07/15/20 08:53 AM
I don't recommend a 100 amp unit.
A lot of people incorrectly think that since the alternator is 90 amp that 100 amp breaker is perfect but that's not how it works.
We've built a starter tester for Borg Warner at my work and under load a starter can draw 800 amps. Hence why batteries have Cold Cranking Amp ratings that high. You get by with 6-8 gauge wire because it's usually such a short amount of time cranking and the wire doesn't have enough time to heat up. But with the battery in the trunk you now have 18 feet of battery cable instead of 3. More resistance = more heat = less power at the unit doing the work (starter).
Agreed. Mine is probably 200. I do know that once on a very cold winter morning with the car sitting outside I did pop the breaker when trying to start the car.
I'm running a 200 or 250A breaker. Basically it's just there for if there's a major short circuit in the actual positive cable. Everything else is fused on its own elsewhere.
97 CBR900RR
2012 Hyundai Veloster
Posts: 3537 | From: Near Seattle, Washington | Member Since: 06/02/08 | IP: (172.76.17.66) |
0 registered and
19 anonymous users are browsing this forum.
