Brake Fitment help!
Nathan
Montreal
Hey I know that the 3000gts brakes fit the gvr4 as long as you have the space and I was wondering if there are any other OEM brakes out there that fit the gvr4s?
Thanks!
EMX5636
Bucks County, PA
Baer Track claws use PBR calipers which are OEM minus the Baer logo for F-Body and Mustang in the mid-late 90's, early 2000's. The closest bolt on is probably the Gen1 CTS-V caliper, which doesn't need a bracket, just needs to shim the rotor out with a small spacer and a little grinding I think.
mk2davis
Ventura, CA
I don't know if you have 4 or 5 lug set up, but peruse the How To and Info Archive. I think there are 4 or 5 write ups using different combinations.
