Speedometer problem
galantrevolution
las vegas, nv
I have a problem with my speedometer it reads 5mph more than actual speed , already replace the gear at the trans, what could be the problem ?
clevr4
Rhoadesville, virginia
Running stock wheels?
Toronto, ON, Canada
Couldn't help but notice you have an 'RS swap' - does that mean you're running the 3.909 rear diff and matching transmission?
Toronto, ON, Canada
what's your trans code? if it's from an October 1989 RS with the W5M33 transmission, it's going to be expecting a 3.909 rear diff ratio.. if you have a KM225/C50/C51 trans then you have the earlier 3.545 trans.
holeshotmoe
MD
It will wear your VC out pronto if it turns out the rear ratio is incompatible with the trans. 89Patches has the 3.909 gears if you need them... LINK
galantrevolution
las vegas, nv
Here the transmission code Kw5m332npxv
Rb7291 so is this a JDM trans and what differential to I need to match that transmission
Toronto, ON, Canada
That's not a JDM RS transmission - that's a 1G DSM AWD trans which would match your stock 3.545 rear end. I think the DSM runs taller tyres stock than the GVR-4 so maybe that's where your inaccuracy comes from.
Indianapolis, IN
A DSM transmission is set to run with tires that are just over 1/2" taller than the stock GVR4 ratio. So, you will have speedo issues unless you run a ratio that equals the 1g DSM standard of 205/55r16, or a 631.5mm tall tire.
Toronto, ON, Canada
Or you could swap in the GVR-4 speedo drive unit
