unistylef
Hello all! I'm quite pleased with my new-to-me 92 Belize Green.
No pics yet, but its in great condition.
Just wanted to say, I understand this is a community. Every member of a community should have something to contrib, so I will state that I am a confident photographer, graphic designer, and webmaster. So, if you need anything, let me know. I'll see what I can accomplish.
[P1=POWER][P2=HANDLING][P3=APPEARANCE][P4=REGULATION COMPLIANCE][P5=REBUILD]
[V=VARIABLE][P=PENDING][T=TRIAL][IP=IN PROGRESS]
CURRENT
STAGE 1: FOCUS: [P1/P5]
#_____| 996/ 1000
TRIM__| 1992 BELIZE GREEN A87
NAME__| [T] KAPPA 996 SSS (Super Street Sedan)
GOAL__| USTREET/ AUTOX/ Track, Higher Powerband, Responsive
COMMON| 30-65MPH, 90-115MPH
POWER_| EXPECTED 350-400AWHP
TURBO_| EVO3 16G @ [V] 20-21PSI+
MOTOR_| 4G63, 272 CAMS
FUEL__| (San Diego: 91 OCT) 550CC
SUSP__| [T] F: EVO8 KYB R: EVO8 BILSTEIN, SWIFT SPRINGS
TIRES_| [V/P] 225/40/R17 SUMMER PERFORMANCE
UPCOMING 2014/2015
STAGE 2: FOCUS: [P2/P3/P4]
FUEL | (SAN DIEGO: 91 OCT) / [P] E85
SUSP | [P2] F/R SWAY BAR
LSD | [P2] QUAIFE
TRANSM| [P5] EVO3 1ST/5TH GEAR
REAR | [P5] 4 BOLT
PAINT | [P/P3] Either: Brit Racing Green or BMW Forest Green, REMAIN DEBADGED
SAFETY| [P4] TUNING SPEC SEATS, 4PT HARNESS, 6pt WELD-IN ROLLCAGE, Fire Extinguisher
UPDATED DETAILED PARTS LIST:
<b>ENGINE</b>
<ul type="square"> MLS HEAD GASKET
ARP HEAD BOLTS
NGK -7 PLUGS @.022 GAP, NGK SPARK WIRES
272/272 CAMS (REGRINDS)
ALUMINUM HALFMOON GASKET
FACTORY OIL FILTER W/ SHELL ROTELLA 15W-40
</ul>
<b>EXHAUST</b>
<ul type="square"> EVO 3 MANIFOLD - CERAMIC COATED, PORTED,
ARP TURBO BOLTS
FULL 3" TURBO BACK: STAINLESS STEEL, MANDREL BENT
3" DOWNPIPE - PAINTED & HEAT WRAPPED
3" MAGNAFLOW CAT
3" MAGNAFLOW MUFFLER: SINGLE TIP </ul>
<b>FUEL</b>
<ul type="square"> WALBRO 255 LPH
AFPR @ 37PSI
EVO 8 INJECTORS 560CC (CURRENT)
860CC (LATER FOR 22+ PSI) </ul>
<b>AIR</b>
<ul type="square"> ETS FMIC (24” x 10” x 3” Bar and Plate core)
2.5” IC PIPING
2G MAF
2G INJEN INTAKE
MANUAL BOOST CONTROLLER </ul>
<b>TURBO</b>
<ul type="square"> 19-20PSI
MHI EVO 3 16G: CERAMIC COATED, PORTED
O2 SENSOR: CERAMIC COATED </ul>
<b>DRIVETRAIN</b>
<ul type="square"> ALUMINUM FLYWHEEL
METAL SHIFTER BASE BUSHINGS
BASE BUSHINGS
JNZ DRIVESHAFT REBUILD KIT
ACT 2600 CLUTCH
CUSTOM 1G SHORT SHIFTER
TRANSMISSION: LUCAS FULL SYNTHETIC 75-90 W/ LUCAS OIL STABILIZER
SOLID TRANNY BUSHINGS
STAINLESS CLUTCH LINE </ul>
<b>SUSPENSION</b>
<ul type="square"> EVO 8 SWIFT LOWERING SPRINGS
FRONT: STRUT BAR, EVO 8 AGX STRUTS
REAR: STRUT BAR, EVO 8 BILSTEIN STRUTS
NEW BALL JOINTS </ul>
<b>WHEELS</b>
<ul type="square"> 5 LUG SWAP: NEW WHEEL BEARINGS & SEALS
EVO9 ENKEI RIMS: 17"X8" 35MM OFFSET
DUNLOP DIREZZA SUMMER PERFORMANCE: 225/40/17 </ul>
<b>BRAKES</b>
<ul type="square"> JNZ ABS DELETE KIT W/ PROP VALVE
SS BRAKE LINES
FRONT: 3000GT ROTORS 313MM, 3000GT CALIPERS 4-PISTON FIXED
REAR: 1G STANDARD </ul>
<b>ELECTRONICS</b>
<ul type="square"> REBUILT ECU
ECM V3
VDO BOOST GAUGE </ul>
<b>OTHER</b>
<ul type="square"> '89 GSX GRILL
'89 UNDERDASH
DSM 1G STEERING WHEEL
JDM HEADLIGHTS: 6k HID
Mint Fogs: Yellow HID
LED Bulbs throughout
BATTERY RELOCATION: FOR 2G INTAKE </ul>
CURRENT
#_____| 996/ 1000
UPCOMING 2014/2015
LSD | [P2] QUAIFE
REAR | [P5] 4 BOLT
<b>ENGINE</b>
ARP HEAD BOLTS
</ul>
<b>EXHAUST</b>
ARP TURBO BOLTS
3" MAGNAFLOW CAT
<b>FUEL</b>
AFPR @ 37PSI
<b>AIR</b>
2.5” IC PIPING
2G MAF
2G INJEN INTAKE
<b>TURBO</b>
<b>DRIVETRAIN</b>
BASE BUSHINGS
ACT 2600 CLUTCH
<b>SUSPENSION</b>
<b>WHEELS</b>
<b>BRAKES</b>
SS BRAKE LINES
<b>ELECTRONICS</b>
ECM V3
<b>OTHER</b>
'89 UNDERDASH
