was the transmission in neutral? do you have an LSD both front and rear? Do you know how worn out your viscous center coupling is?
If you lifted one of the front corners to spin, seeing as you are unlikely to have a front LSD the drive would just get transferred back to the center diff in the gearbox which would have just directed the drive further upstream to the gearbox itself. There should have been some resistance as the other end is on the ground but if you have a worn out or non-existent viscous center diff coupling then it will act like an open diff.
The thing with our cars is that if you don't have a front or rear LSD diff all it takes is one wheel from each end to spin freely and then you lose all traction. If your center diff viscous coupling is worn out or non-existent then all it takes is ONE wheel to spin free and then you have no traction to the rest.
