Quoting galant1517:
The most common boost leaks that you will find are throttle shaft seals, the injector insulators (lower seals), pcv hose, and leaks at the piping couplers. But there are many other places too. Off of the top of my head:
Intake manifold gasket
throttle body gasket
throttle body elbow gasket
egr valve gasket
bad pcv valve
blow off valve
BOV gasket/seal
BISS o-ring
vacuum lines
cracked/broken I/C
compressor housing o-ring (or lack of)
J-pipe gasket
and I'm sure there is more.
Thanks for the list. I'm familiar with the obvious ones, which is why I am having a hard time tracking it down. While doing the test, the boost gauge doesn't move either. I can hear air escaping and when I have gone wide open it pulls nicely at 15 pounds.
I considered the compressor gasket as I had the same problem with my fp3065, I made a thread years ago and solved that problem with rtv. I'll try again this week and post up. Also unsure of the brand of 50 trim on the car.
