Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » got some dyno numbers!! Video added!
Ben
Galant VR-4 org Post #: 972891 posted 02/26/11 11:39 PM     Remind Me!  Send Private Message   Edit Post
to the front wheels: 421, 90 oct, 17 psi.
651, e85, 28 psi
We stopped there because I didn't have my head machined smooth enough for a metal gasket. Cyl pressure was pushing through those tiny grooves over to the nearest coolant jacket. When we got into the 600s, my coolant overflow jug overrun hose became a high pressure coolant waterhose towards the end of a pull. lol! Eventually I need to pull my head, have it machined smoother and have it o-ringed too. We had a hard time getting traction on the dyno. That 651 is fat rich, super conservative and only 2 degrees of timing because my knock sensor is picking something up. I need to get that firgured out. rev limiter is set at 9250 and it's still makeing power at that rpm. Hasn't plateaued yet haha.
He made me drive it and it was scary.... punched it in 3rd and lost traction to all 4 tires when the turbo spooled. It felt insane like an explosion. Kinda hard to describe the intensity of the pull you feel when you have the power to break all 4 tires loose in 3rd gear.
Andrei(tuner at Abel racing doing this) said if this engine would hold, the potential for close to 800 is there.
I was hoping to break 600 with 35 or so psi. I had no idea I was going to pass that mark so easliy with less than 30 psi on a turbo cable able of over 40! haha.
Here's my build: click
Edited by Ben (02/27/11 05:15 PM)
Posts: 199 | From: Lubbock, Tx | Member Since: 01/14/09 | IP: (75.111.51.65) | Report this post to a Moderator
GolfBall
1900/2000
Galant VR-4 org Post #: 972946 posted 02/27/11 12:09 PM     Remind Me!  Send Private Message   Edit Post
congrats ben,
those are some good numbers for sure. Get your head gasket sorted out. mls and some L19's and your set. haha.
then we can race in texas at tx 2k11.
PRECISION AUTOMOTIVE DEVELOPMENT
1900/2000 - Project Golfball
Buit 2.4 - built AUTO - FP3586 38PSI
Posts: 125 | From: Edmond, OK | Member Since: 08/28/09 | IP: (68.97.242.83) | Report this post to a Moderator
Ben
Galant VR-4 org Post #: 972958 posted 02/27/11 01:11 PM     Remind Me!  Send Private Message   Edit Post
I doubt I go any more. My trip to okc drained my account and my truck decided to loose all its power on the way back. That cost me another night in a hotel. I won't be able to fix my car before 2k11. I'm worried about having my head machined again too. It's already had a lot taken off the surface. I do have a mitsu mls, but just regular arp head studs. I will have videos up today
Edited by Ben (02/27/11 01:12 PM)
Ben
Galant VR-4 org Post #: 973006 posted 02/27/11 05:14 PM     Remind Me!  Send Private Message   Edit Post
475/1000
Galant VR-4 org Post #: 973020 posted 02/27/11 05:56 PM     Remind Me!  Send Private Message   Edit Post
Badass
Have you weighed the car yet?
92 GVR4 0475/1000
Greenhouse Effect Green
Exceeds Mechanical Limits
"Put the dawg to work.
Posts: 11892 | From: Clarksville TN | Member Since: 05/04/03 | IP: (8.27.208.114) | Report this post to a Moderator
Tre3zy
correct me if im rite...Wyldcarz been rolling hard for a long time
637/2000
Galant VR-4 org Post #: 973025 posted 02/27/11 06:15 PM     Remind Me!  Send Private Message   Edit Post
GARAGE BUILT
#ZukiFab / Tuned
Build Thread:
Current Personal Best 11.75 @ 119
Posts: 602 | From: South San Francisco, CA | Member Since: 11/25/08 | IP: (67.169.105.18) | Report this post to a Moderator
Ben
Galant VR-4 org Post #: 973035 posted 02/27/11 07:02 PM     Remind Me!  Send Private Message   Edit Post
Havnt weighed it yet. Brant said full race weight with driver and co-driver was 3100. I have less stuff in the car than brant I'm sure. I need to go see what it weighs.
Posts: 199 | From: Lubbock, Tx | Member Since: 01/14/09 | IP: (173.139.204.205) | Report this post to a Moderator
2of9
Hellaflush
Galant VR-4 org Post #: 973059 posted 02/27/11 08:25 PM     Remind Me!  Send Private Message   Edit Post
awesome numbers man. congrats!
Team Nines DSM Specialist
Posts: 869 | From: IGH, MN | Member Since: 08/29/07 | IP: (97.127.96.214) | Report this post to a Moderator
1qkfwd
1868/2000
Galant VR-4 org Post #: 973118 posted 02/28/11 12:17 AM     Remind Me!  Send Private Message   Edit Post
Dam your build is very close to mine. Numbers look good. Could you have gotten more out of the 90 oct?
92 eclipse FWD [email protected]
92 Talon AWD Best et [email protected] 1.39 60'
2011 GTX series here we come!
#1868/2000 Looking for 10s on pump
Posts: 209 | From: Sun Valley, NV | Member Since: 09/29/09 | IP: (166.205.138.80) | Report this post to a Moderator
onesickcrx
Brother of the Year
449/2000
Galant VR-4 org Post #: 973129 posted 02/28/11 12:53 AM     Remind Me!  Send Private Message   Edit Post
28psi 650+ hp on low compression thats nuts I like
Lack of boost
Posts: 1076 | From: NY | Member Since: 06/03/07 | IP: (69.116.42.216) | Report this post to a Moderator
Rivet
Galant VR-4 org Post #: 973133 posted 02/28/11 01:06 AM     Remind Me!  Send Private Message   Edit Post
Was that a 3rd gear pull or did you start in 2nd?
| | | IP: (76.100.241.129) | Report this post to a Moderator
Ben
Galant VR-4 org Post #: 973137 posted 02/28/11 01:19 AM     Remind Me!  Send Private Message   Edit Post
Quoting 1qkfwd:
Maybe, but it was showing knock so we stopped there. Andrei kept saying my car was going to make legendary numbers on pump. We just didnt have 93 or time. The knock sensor was showing knock on the e85 also, which he said e85 will not knock. A piston will melt before you show any knock on e85. So knowing this, we probably could have taken the 90 oct further. But that's not worth it. It's still stupid fast(to me) on 90 oct. All 4 break loose going into 2nd hard on 90. When I get some more stuff figured out, I can't wait to mount my slicks and set up the launch control!!! I have to find out what my knock sensor is picking up.
And all 3rd gear. I will get more videos up tomorrow
Edited by Ben (02/28/11 01:20 AM)
1qkfwd
1868/2000
Galant VR-4 org Post #: 973200 posted 02/28/11 12:21 PM     Remind Me!  Send Private Message   Edit Post
You reading the plugs after each run to make sure your not showing any signs of detonation? I wish we had E85 close. Where stuck on shit 91 as our premium pump gas.
Brianawd
Higher Launch RPM
439/1000
Galant VR-4 org Post #: 973205 posted 02/28/11 12:44 PM     Remind Me!  Send Private Message   Edit Post
E85 will knock. When it does most of the time damage has already been done. Was your knock progessive of a big spike and then went away? Also when doing the pull did the guy just stap the thottle or roll into it? If you just stab the throttle at 3k that will cause knock. Once it starts knocking that way,most of the time it keeps knocking tell you let off the gas and get back into it. Also what rpm is the knock starting at?
1992 Gaylant vr4 #439/1000
11.1at131 562awhp/484awtq
E85 FP3052 parted out
05 EB EVO SSL 11.48at124mph
450awhp/400awtq New 2.3 e85 hks 7460r
05 JEEP liberty CRD DD/ski slut
200hp/385tq
Posts: 2117 | From: Portland OR, | Member Since: 04/18/05 | IP: (134.134.137.71) | Report this post to a Moderator
Ben
Galant VR-4 org Post #: 973340 posted 02/28/11 08:10 PM     Remind Me!  Send Private Message   Edit Post
It was knocking around 3k rpm a part throttle(it didn't start that til I had about 200 miles on the engine). I just realized that he raised the point at which the ecu starts looking at knock to 3500 so it's not seeing that any more.
He was rolling into it slow. Sometimes, super slow trying to help with traction on the dyno. He said pretty much the same thing that you could melt a piston and may not see any knock. haha. I did not see the logs so I don't know if/when/how it was comming in. I do not think the knock went away.
I have only driven the car 8-10 miles since the tune and got on it a few times. On pump, it started knocking(looking at the factory boost gauge) as soon as it was in the power the whole time. It did the same thing the one time I made an e85 pull. I'm going to try to make some logs tonight and look at a few things. I don't know much about tuning at all. Also at consistant throttle(cruising) I have a stumble and my afr jump around from about 13-16.
1qkfwd
1868/2000
Galant VR-4 org Post #: 973386 posted 03/01/11 12:24 AM     Remind Me!  Send Private Message   Edit Post
I'm on link forums, you can pm me a couple pulls I can take a look at them. I'm 1qkfwd over there also. I've been a link user since 05. Even tuned a few cars via email.
Posts: 209 | From: Sun Valley, NV | Member Since: 09/29/09 | IP: (166.205.136.175) | Report this post to a Moderator
Ben
Galant VR-4 org Post #: 973389 posted 03/01/11 12:39 AM     Remind Me!  Send Private Message   Edit Post
Will do in the morning!! I made some logs tonight. Thanks
Olson
Pwnd by Rance.
338/2000
Galant VR-4 org Post #: 973410 posted 03/01/11 04:49 AM     Remind Me!  Send Private Message   Edit Post
Nice numbers dude. On another note the car look very peaky so to speak aren't you going to want a broad power band?
338/2000
05 TDI Wagon
88 Raider
"Oh, and if you want to build your status and rank, go play some WoW. Come back when you're ready to talk cars". Qship
Posts: 1237 | From: Moreno Valley CA | Member Since: 10/08/06 | IP: (180.131.229.0) | Report this post to a Moderator
Ben
Galant VR-4 org Post #: 973420 posted 03/01/11 08:11 AM     Remind Me!  Send Private Message   Edit Post
That pull was still spinning on the dyno so there is a little more power band than what this video shows. It's still a laggy turbo that doesn't get started til the 5-6k rpm range(that's when the explosion happens!), but my car is still making power over 9k. That is enough that it doesn't fall out of the power when I shift. It reminds me of my banshee, crazy 2 stroke powerband!
Garfield Wright
Galant VR-4 org Post #: 973437 posted 03/01/11 09:53 AM     Remind Me!  Send Private Message   Edit Post
Nice #s
| | | IP: (66.229.166.41) | Report this post to a Moderator
KiNgMaRtY
Member +++
802/1000
Galant VR-4 org Post #: 973519 posted 03/01/11 03:16 PM     Remind Me!  Send Private Message   Edit Post
Ver very nice numbers indeed
92 GVR4 #802 link
17 CTS-V,06 Evo IX MR, 98 Montero
94 MX5 M-Edition - On Xidas, LS1 Swap in progress
SOLD: 92 GVR4 #611
Posts: 793 | From: Corona, CA | Member Since: 04/08/08 | IP: (99.32.5.18) | Report this post to a Moderator
Brianawd
Higher Launch RPM
439/1000
Galant VR-4 org Post #: 973543 posted 03/01/11 04:53 PM     Remind Me!  Send Private Message   Edit Post
PM me on link. Name there is brianawd and send me a 3rd gear pull. One where you stab the throttle at 3k and when where you roll into it slow. Pull all the way to 8k
200hp/385tq
Posts: 2117 | From: Portland OR, | Member Since: 04/18/05 | IP: (184.76.113.151) | Report this post to a Moderator
Ben
Galant VR-4 org Post #: 973604 posted 03/01/11 07:54 PM     Remind Me!  Send Private Message   Edit Post
I will make more logs tongiht that aren't as long. I'll have some cruising to watch the afrs cycle up and down, then a few 3rd gear pulls.
1qkfwd and I have been talking throughout the day about the possibilty of a mechanical fuel flow issue. I don't know how to pm logs on the forum so I have to email them, unless someone knows how to send them through PM.
No time tonight and I'm tired. hopfully tomorrow night or Thursday. I kinda want to go go ahead and pull my head off thursday morning.
Edited by Ben (03/01/11 10:35 PM)
Ben
Galant VR-4 org Post #: 974422 posted 03/04/11 08:51 AM     Remind Me!  Send Private Message   Edit Post
This evening I'll post pics of the hole in my piston. yyyeeesssssss
DarylNilsen
Galant VR-4 org Post #: 974454 posted 03/04/11 11:41 AM     Remind Me!  Send Private Message   Edit Post
Uhhhh ohhh, that's no good. I was just going to ask you to post a street pull up.
| | | IP: (99.49.100.252) | Report this post to a Moderator
Pages: 1 | 2
Generated in 0.186 seconds in which 0.151 seconds were spent on a total of 14 queries. Turbo powered.
