Quoting vtecds1:
Thank you sir...
You mentioned that I can test them...more info on this please. The seller said there is about 3k miles on them, but I take that with a grain of salt.
Any decent machine shop should have a spring compressor/tester guy. You pop the spring in, compress it, and the indicator gives you a reading. Dig up the specs on the OEM springs, and take a couple to a machine shop, or someplace that sells them /ubbthreads/images/graemlins/wink.gif, and check them to see if any are 'saggy' or not up to spec.
You can measure the height of the spring to start, just get you set of calipers.
With the valve spring tester, the spring should rear a specific pressure at a specific compressed height.
As a point of reference the springs in the head pictured (evo springs) were 152# at 1.100". and something like 64# at 1.530".
