Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » Non-Destructive Rear Lower Damper Removal
mooserage Galant VR4.org Administrator
New Title
254/2000
Galant VR-4 org Post #: 1250762 posted 05/14/21 11:16 AM     Remind Me!  Send Private Message   Edit Post
Does anyone have suggestions on removing these without destroying? While removing the damper both bushings came out of the damper and left the lower metal bushing that is stuck and integrated rubber bushing behind.
I could of course cut them off, but there's nothing wrong with the performance of these dampers, so I'd like to try and save them.
Posts: 1263 | From: Seattle, WA | Member Since: 05/17/04 | IP: (73.19.21.252) | Report this post to a Moderator
Imback
Newbie
Galant VR-4 org Post #: 1250770 posted 05/15/21 03:00 AM     Remind Me!  Send Private Message   Edit Post
So the inner sleeve froze to the knuckle?
1316
Posts: 7 | From: Suffolk,NY | Member Since: 10/27/17 | IP: (72.69.11.247) | Report this post to a Moderator
christo
Galant VR-4 org Post #: 1250795 posted 05/17/21 03:36 PM     Remind Me!  Send Private Message   Edit Post
Small gear puller maybe, see if you can spray some silicon and use a small screwdriver or something to see if you can work the bushing loose from the metal.
Chris Mclean
Posts: 199 | From: Fairhope, AL | Member Since: 02/07/03 | IP: (170.249.155.210) | Report this post to a Moderator
JNR
20/1000
Galant VR-4 org Post #: 1250796 posted 05/17/21 05:58 PM     Remind Me!  Send Private Message   Edit Post
This may be worth a try: If you turn a compressed air can upside down while spraying, it is extremely cold...Spray the rubber (only) liberally as to have it contract and it's possible that you can then pull it off.
Posts: 9789 | From: ca | Member Since: 04/23/04 | IP: (172.119.79.236) | Report this post to a Moderator
New Title
254/2000
Galant VR-4 org Post #: 1250797 posted 05/17/21 06:04 PM     Remind Me!  Send Private Message   Edit Post
Thanks for the suggestions, I'll try a couple of things tonight.
I tried a gear puller, but it can't grab on the rubber bushing and I wouldn't want it to dig in too hard anyway. I do have one thing I might be able to try there as well though.
Will report back with the findings...
Posts: 1263 | From: Seattle, WA | Member Since: 05/17/04 | IP: (205.166.76.242) | Report this post to a Moderator
0 registered and 26 anonymous users are browsing this forum.
Generated in 0.056 seconds in which 0.045 seconds were spent on a total of 14 queries. Turbo powered.
