Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Well I'm Doing a in Car Rebuild! Advise?
turbophein
Member ++
1079/2000
Galant VR-4 org Post #: 899420 posted 05/17/10 08:17 AM     Remind Me!  Send Private Message   Edit Post
lost compression in cyl #1. i pulled the head the other day. the cyl walls look great.
so i plan on throwing some new NPR piston & rings in the motor, with some acl rod bearings and a oem headgasket.
parts should be well under $200 easily. pistons are $90, headgasket $55, acl's $20, exhaust mani gasket $22
so today i am going to pull the exhaust completely, pull down the TC and drop the driveshaft, pull the oil pan, and remove the rods and pistons.
then do a quick hone, and reinstall everything!
if someone has done this and has any tips for me, that would be awesome!
should be a decent rebuild when done!
E16g, fmic, 1000's, SD, v3, LC2 WB, fp2 cams, ARP's, etc
Posts: 682 | From: mass | Member Since: 02/17/09 | IP: (24.63.173.179) | Report this post to a Moderator
DR1665
Kill him in the face with Wilson Phillips
Galant VR-4 org Post #: 899680 posted 05/17/10 10:06 PM     Remind Me!  Send Private Message   Edit Post
I've done this. Sometimes, you gotta do whatcha gotta do. It wasn't fun. The only nice part about it was finding the 12mm wrench I lost when the engine went in months before.
Yeah buddy. Doesn't that look like fun?
If you're gonna do a cheap rebuild, might as well try to clean things up a bit while you're in there.
Posts: 4631 | From: Phoenix, AZ | Member Since: 10/19/05 | IP: (70.176.240.200) | Report this post to a Moderator
475/1000
Galant VR-4 org Post #: 899700 posted 05/17/10 10:52 PM     Remind Me!  Send Private Message   Edit Post
Don't forget the main bearings. Your there and might as well do it. I didn't and it cost me going into JSB status for to damn long.
92 GVR4 0475/1000
Greenhouse Effect Green
Exceeds Mechanical Limits
"Put the dawg to work.
Posts: 11892 | From: Clarksville TN | Member Since: 05/04/03 | IP: (208.95.177.176) | Report this post to a Moderator
belize1334
1334/2000
Galant VR-4 org Post #: 899828 posted 05/18/10 11:55 AM     Remind Me!  Send Private Message   Edit Post
To do the mains you have to pull the crank which means pulling the transmission to drop the FW. If you're pulling the transmission you may as well pull it all and do it right.
Roger B. Scott
'91 Belize Green
Posts: 3313 | From: Dundee, Scotland, UK | Member Since: 11/18/03 | IP: (174.45.93.14) | Report this post to a Moderator
turbophein
Member ++
1079/2000
Galant VR-4 org Post #: 899861 posted 05/18/10 01:14 PM     Remind Me!  Send Private Message   Edit Post
i'm not planning on doing the mains because i am leaving the motor in the car...
i got it all ripped apart just now, i took some quick pics of the old bearings...
plus i read a lot of different threads that stated the mains last longer, if your end play is good, than to just leave it alone. not like i checked my end play or anything but, its really under $200 not that bad of a gamble. i will drive the car maybe 2500 miles a year, if it ever stays running!
Edited by turbophein (05/18/10 01:24 PM)
turbophein
Member ++
1079/2000
Galant VR-4 org Post #: 903087 posted 05/30/10 11:35 AM     Remind Me!  Send Private Message   Edit Post
well i finished the build, did NPR pistons, acl rod bearings, oem headgasket and a quick hone. i have 40 miles on it so far and it feels great. response is much better so far. after 500 miles i will really let you know how it went.
alansupra94
Excuse the retarded question.
4/1000
Galant VR-4 org Post #: 903139 posted 05/30/10 03:29 PM     Remind Me!  Send Private Message   Edit Post
Nice...I am surprised no one told you to get 2G pistons for that nice off boost 8.5 to 1 compression
1992 Galant VR4
1996 Toyota Supra TT
Posts: 1909 | From: Wayne,NJ | Member Since: 03/03/10 | IP: (173.3.24.20) | Report this post to a Moderator
Generated in 0.068 seconds in which 0.054 seconds were spent on a total of 14 queries. Turbo powered.
