Galant VR-4 Forums » Galant VR-4 » Technical Discussions » the car keeps dieing
steverussell
Galant VR-4 org Post #: 899339 posted 05/16/10 09:58 PM     Remind Me!  Send Private Message   Edit Post
I'm having problems driving. I'm not sure how to explain this so bare with me. When I'm driving and go to shift and let the rpms drop the car wants to die and sometimes does. Then if driving and just put the car in nuetral the will car die. So today I checked over everything on the car made sure I didnt have any vaccum leaks zip tied everything. I put on a hks bov today. Cause the last bov had a little hole on the back so it would let out alittle air and I thought that maybe the problem. But it still dies and I don't know why.
| | | IP: (75.132.3.139) | Report this post to a Moderator
deez
Nutz
Galant VR-4 org Post #: 899341 posted 05/16/10 10:01 PM     Remind Me!  Send Private Message   Edit Post
Welcome to the world of Mitsubishi, have fun. I've been fighting a similar problem for over a year.
#802/1000 Daily Driver SOLD!
1960 Austin Healey Bugeye
Posts: 1150 | From: Chico, CA | Member Since: 05/29/04 | IP: (70.136.41.67) | Report this post to a Moderator
broxma
retard monkey strength
379/1000
Galant VR-4 org Post #: 899356 posted 05/16/10 10:34 PM     Remind Me!  Send Private Message   Edit Post
Cars usually die due to lean conditions. Generally this is due to non metered air getting into the system past the MAF seonsr. First things to check are, would you be venting your BOV to atmosphere? Have you pressure tested the intake tract at the turbo inlet? Have you cleaned or tested your ISC motor? Generally checking these three things will locate the cause of the problem. I recently had a voltage issue which was causing my car to die but it was unique to the wiring I had done for the alternator relocation. I do suspect that the open BOV had something to do with it although it was most likely a combination of the two.
One thing to do when you do the intake pressure test is get a spray bottle with a small amount of soap and spray it on places that could leak such as the injector seals, TB area and the mating surface at the intake manifold.
The other reason I can think of a car dying off throttle is severely low compression as was the case with my 1972 Pontiac LeMans.
/brox
I am big into recycling though and if your not into sacrifice or burnt offerings, you may want to stick with 93 octane.
/brox
Posts: 911 | From: San Antonio Tx | Member Since: 11/16/09 | IP: (99.52.72.193) | Report this post to a Moderator
steverussell
Galant VR-4 org Post #: 899360 posted 05/16/10 10:43 PM     Remind Me!  Send Private Message   Edit Post
The bov is recirulated. I've never cleaned the isc motor or did a pressure test. I guess those things are next on my list.
Edited by steverussell (05/16/10 10:46 PM)
| | | IP: (166.137.140.15) | Report this post to a Moderator
Smitty1457
Galant VR-4 org Post #: 899368 posted 05/16/10 11:23 PM     Remind Me!  Send Private Message   Edit Post
vfaq.com for how to test isc. That little bastard causes issues.
| | | IP: (76.105.249.16) | Report this post to a Moderator
Generated in 0.135 seconds in which 0.108 seconds were spent on a total of 14 queries. Turbo powered.
