Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Brake line fittings for Ron big brake upgrade
Too Clean
1881/2000
50/1000
Galant VR-4 org Post #: 511806 posted 07/28/07 10:55 AM     Remind Me!  Send Private Message   Edit Post
Does anyone know the part numbers I need to use stock lines w/ the Camaro calipers? I know people have mentioned two pieces that you need, but I can't find any links to the actual parts or anything.
-Jeff
1881/2000
50/1000
Posts: 7872 | From: KC, Missouri | Member Since: 08/08/04 | IP: (65.28.102.107) | Report this post to a Moderator
Senior Ricer
1552/2000
Galant VR-4 org Post #: 511825 posted 07/28/07 12:17 PM     Remind Me!  Send Private Message   Edit Post
I didn't use the stock lines, I got two #3AN lines (made by BCE) that were about the same length as the stockers (maybe 9 inches?) and got adapters for each end. If you need the part numbers I probably have the receipts at home.
John
Posts: 13235 | From: Orange County, NY | Member Since: 09/11/03 | IP: (4.237.180.224) | Report this post to a Moderator
GVR4Jay
Galant VR-4 org Post #: 511827 posted 07/28/07 12:20 PM     Remind Me!  Send Private Message   Edit Post
They are 90's acura integra lines and they go straight from the caliper to the hard lines on our cars.
| | | IP: (69.232.210.190) | Report this post to a Moderator
Senior Ricer
1552/2000
Galant VR-4 org Post #: 511830 posted 07/28/07 12:28 PM     Remind Me!  Send Private Message   Edit Post
That's one way to do it but its hard to find just a front set of lines and to expensive to buy a set of four when all you need is two. Either way it'll work.
John
Too Clean
1881/2000
50/1000
Galant VR-4 org Post #: 512243 posted 07/29/07 10:42 PM     Remind Me!  Send Private Message   Edit Post
Hmm, I'd like to get the part numbers from you John if you wouldn't mind. Anybody know if the acura lines are the same on all 4? It would be easy to sell off the half I didn't use if that were the case.
-Jeff
1881/2000
50/1000
Luke
201/2000
Galant VR-4 org Post #: 512866 posted 07/31/07 01:06 AM     Remind Me!  Send Private Message   Edit Post
I believe I used 95 civic front brakelines.
I got them from fastbrakes.com
2.3L 6-bolt, BJ's ported 2G head, TRE tranny, GT3076R, 255lph, 850cc, AFPR, ROM emulator, Aquamist, ETS FMIC, LSD rr Quaife ft diff, WL swaybars, Bilstein, HKS 264/272 cams, ZT2 WBO2
Posts: 752 | From: San Jose, CA | Member Since: 07/16/02 | IP: (75.35.109.244) | Report this post to a Moderator
Senior Ricer
1552/2000
Galant VR-4 org Post #: 513177 posted 07/31/07 02:38 PM     Remind Me!  Send Private Message   Edit Post
I'll do my best to get them tonight.
Posts: 13235 | From: Orange County, NY | Member Since: 09/11/03 | IP: (70.107.68.12) | Report this post to a Moderator
ron
Galant VR-4 org Post #: 513200 posted 07/31/07 03:04 PM     Remind Me!  Send Private Message   Edit Post
I think the rear brake lines are a little too short.
I think John's set up is probably better. You can get -3 An line and 2 fittings.
10mm banjo to -3 AN
Banjo Bolt or you can use the ones that came with the calipers
an to female 10mmx1.0
| | | IP: (67.114.159.41) | Report this post to a Moderator
Senior Ricer
1552/2000
Galant VR-4 org Post #: 513235 posted 07/31/07 04:23 PM     Remind Me!  Send Private Message   Edit Post
Despite the pile of receipts that is so large it pains me to see them and think of the money I've blown on this car, I can't find that one. I went to the website of the place I bought them from and came up with this list:
EAR989534 - Earl's Tubing Adapter -3 to 10mm x 1.0 Female - $3.96 from Behrents x 2
EAR997631 - Earl's -3 AN Banjo - 10mm hole diameter - $6.29 from Behrents x2
BSC #3 Hose x2
I think the hose I got was 9" but you can just check the length of a stocker and add a little bit to it. I don't see any 9" hoses in the list so you may have to call them to order it. BTW the place I linked to is a performance warehouse that is local to me and usually has better prices than Summit or Jeg's. Its a great place to deal with since its smaller than the other two places and the owner is almost always in his office right behind the front counter. They do mostly circle track stuff but they have any kind of AN part you might ever need in stock. The lines are not "street legal" but if they're good enough for a Dirt Modified they are good enough for me.
John
Too Clean
1881/2000
50/1000
Galant VR-4 org Post #: 513422 posted 07/31/07 11:50 PM     Remind Me!  Send Private Message   Edit Post
Thanks a bunch for the part numbers, both of you. Can we add this to the how-to section?
-Jeff
1881/2000
50/1000
Too Clean
1881/2000
50/1000
Galant VR-4 org Post #: 552927 posted 10/23/07 10:57 PM     Remind Me!  Send Private Message   Edit Post
As an update for those who are trying to piece this kit together, I ordered the banjo fitting and metric to AN adapter that act250r had mentioned above. However, I found that the metric to AN fitting had a concave mating edge, which doesn't do much when mating to a male, flared brake line like the stock line. I found the correct part to be Earl's 989545ERL and got it through Summit here. In any case, what you're looking for is an Inverted flare fitting on the female side.
-Jeff
1881/2000
50/1000
Posts: 7872 | From: KC, Missouri | Member Since: 08/08/04 | IP: (24.163.196.170) | Report this post to a Moderator
Luke
201/2000
Galant VR-4 org Post #: 553963 posted 10/25/07 09:51 PM     Remind Me!  Send Private Message   Edit Post
I don't understand why folks would not just use the 95 civic FRONT brakelines as I mentioned in the FAQ section ( and also in this thread ).
It is only 65 bucks for the pair.
And there's no part wasted, because you can buy JUST the FRONT lines from fastbrakes.com
Edited by Luke (10/25/07 09:51 PM)
Posts: 752 | From: San Jose, CA | Member Since: 07/16/02 | IP: (125.161.49.177) | Report this post to a Moderator
Senior Ricer
1552/2000
Galant VR-4 org Post #: 554367 posted 10/26/07 05:42 PM     Remind Me!  Send Private Message   Edit Post
I did mine the way I did it because I couldn't find the front ones by themselves.
John
Posts: 13235 | From: Orange County, NY | Member Since: 09/11/03 | IP: (68.197.59.65) | Report this post to a Moderator
2 registered and 84 anonymous users are browsing this forum.
Generated in 0.154 seconds in which 0.114 seconds were spent on a total of 14 queries. Turbo powered.
