Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Bad Vibes
Bad Vibes
Galant VR-4 org Post #: 1240821 posted 12/06/17 03:52 PM     Remind Me!  Send Private Message   Edit Post
Over 80mph, with 2 different sets of wheels, I get bad vibrations in my car. so much so that my door starts to move... Anyone have any ideas as to what I should check. The same noise or motion isn't evident at any other speeds slower.
Posts: 1476 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (74.71.86.154) | Report this post to a Moderator
AllanL
Heal and Toe
Galant VR-4 org Post #: 1240822 posted 12/06/17 05:32 PM     Remind Me!  Send Private Message   Edit Post
propeller shaft parts?
Posts: 263 | From: NV | Member Since: 08/05/08 | IP: (210.4.99.82) | Report this post to a Moderator
I ain't no puny human
866/1000
Galant VR-4 org Post #: 1240825 posted 12/06/17 06:18 PM     Remind Me!  Send Private Message   Edit Post
What carrier bearing bushings are you running. I used to have a vibration/strum because I was using Torque Solution solid bushings. I swapped over to new Outlander bushings, vibration gone.
Thom
Posts: 887 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (2601:803:c402:8c) | Report this post to a Moderator
Galant VR-4 org Post #: 1240844 posted 12/07/17 11:15 AM     Remind Me!  Send Private Message   Edit Post
I guess it could be the rear u-joint or the Lobro. Front is new and shimmed as per book.
Outlander bushings
Might you have a part number for these?
The front bolt on the control arm was loose. Good possibility that was the problem. Think my inner tie rod is worn now because of it.
Edited by tektic (12/07/17 01:05 PM)
Posts: 1476 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (47.20.58.51) | Report this post to a Moderator
0 registered and 38 anonymous users are browsing this forum.
Generated in 0.081 seconds in which 0.072 seconds were spent on a total of 14 queries. Turbo powered.
