Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Replacement clutch master cylinder for JDM GVR4
mscatchell
Newbie
Galant VR-4 org Post #: 1236033 posted 03/22/17 10:09 PM     Remind Me!  Send Private Message   Edit Post
I recently acquired a JDM Galant VR-4 and while looking it over noticed the clutch master cylinder leaking past the seal into the cabin area. Where can I find a replacement one?
E39A-0000868
Posts: 11 | From: Morton Grove, Illinois | Member Since: 03/22/17 | IP: (2602:306:3711:8d) | Report this post to a Moderator
Galant VR-4 org Post #: 1236039 posted 03/23/17 08:02 AM     Remind Me!  Send Private Message   Edit Post
Do a little study and see if it is actually different than the US version. Even if it is, it may be adaptable.
Otherwise, overnight parts from Japan?
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10768 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
I ain't no puny human
866/1000
Galant VR-4 org Post #: 1236040 posted 03/23/17 09:05 AM     Remind Me!  Send Private Message   Edit Post
Or rebuild it yourself with parts from JNZTuning. Guts will be the same but I believe the line comes out the opposite side
Thom
Posts: 894 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (12.109.79.254) | Report this post to a Moderator
Galant VR-4 org Post #: 1236041 posted 03/23/17 09:31 AM     Remind Me!  Send Private Message   Edit Post
That makes sense too. If diameter is the same (and it should be..), should be easy.
mscatchell
Newbie
Galant VR-4 org Post #: 1236051 posted 03/23/17 12:01 PM     Remind Me!  Send Private Message   Edit Post
Looks like I'll have to go the rebuild route for now. The lines are on opposite sides and the mounting points are different
Eager Beaver
Galant VR-4 org Post #: 1236060 posted 03/23/17 05:03 PM     Remind Me!  Send Private Message   Edit Post
Bolt pattern on the firewall is different for the clutch master cylinder? Interesting.
If that wasn't an issue, then even making a simple inline brake line adapter could "re-route" the line back into a non-side matching master.
C53A 1 of the ~1500
Posts: 1627 | From: THE Ottawa | Member Since: 03/05/05 | IP: (173.33.84.32) | Report this post to a Moderator
G Galant VR4.org Moderator
JDM Unit
486/1000
Galant VR-4 org Post #: 1236066 posted 03/23/17 06:26 PM     Remind Me!  Send Private Message   Edit Post
I can get you the part, send me a pm. Do you have cruise?
www.japanesenostalgiccar.com
www.nostalgic.co.jp
Edited by G (03/23/17 06:41 PM)
Posts: 8896 | From: zompton | Member Since: 02/24/04 | IP: (75.86.151.204) | Report this post to a Moderator
JDM Unit
486/1000
Galant VR-4 org Post #: 1236068 posted 03/23/17 06:50 PM     Remind Me!  Send Private Message   Edit Post
If you don't have cruise this should be it >> click MB012077
www.nostalgic.co.jp
Edited by G (03/23/17 06:52 PM)
mscatchell
Newbie
Galant VR-4 org Post #: 1236085 posted 03/24/17 07:11 AM     Remind Me!  Send Private Message   Edit Post
I just double checked and the car is w/o cruise. I ordered a rebuild kit through RockAuto for a USDM '91. But I will also order a pair of these seals from JNZ. Thanks Guys
mscatchell
Newbie
Galant VR-4 org Post #: 1236167 posted 03/29/17 10:18 AM     Remind Me!  Send Private Message   Edit Post
I'm unable to remove the piston, is there some other retaining ring I'm not seeing?
Galant VR-4 org Post #: 1236171 posted 03/29/17 10:39 AM     Remind Me!  Send Private Message   Edit Post
Quoting G:
There is the clip shown in the box labeled 20110 in the illustrations. Did you remove that?
mscatchell
Newbie
Galant VR-4 org Post #: 1236176 posted 03/29/17 12:09 PM     Remind Me!  Send Private Message   Edit Post
mscatchell
Newbie
Galant VR-4 org Post #: 1236177 posted 03/29/17 12:14 PM     Remind Me!  Send Private Message   Edit Post
The only easy thing that came off after removing the ring was this shaft part.
Galant VR-4 org Post #: 1236179 posted 03/29/17 12:30 PM     Remind Me!  Send Private Message   Edit Post
You may have some corrosion in there. You can soak it or try compressed air through a line hole. Don't look in the end when trying that method.
mscatchell
Newbie
Galant VR-4 org Post #: 1236180 posted 03/29/17 12:34 PM     Remind Me!  Send Private Message   Edit Post
I'll try that and see what happens, only other thing I can think of is to drill a hole in the piston to put a screw in to pull it out since it might have a plastic collar like the replacement.
mscatchell
Newbie
Galant VR-4 org Post #: 1236189 posted 03/29/17 08:28 PM     Remind Me!  Send Private Message   Edit Post
Before I destroy anything, any way to check if this part number will work on a JDM clutch master cyliner
0 registered and 9 anonymous users are browsing this forum.
Generated in 0.112 seconds in which 0.094 seconds were spent on a total of 14 queries. Turbo powered.
