Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Overheating
Overheating
Illinoisinc
Galant VR-4 org Post #: 1215823 posted 09/03/15 09:00 AM     Remind Me!  Send Private Message   Edit Post
Well good morning everyone. New gallant vr4 guy here ( new piston guy as well, been in the rotary world all my life )
Just purchased the car and it is overheating.
I have changed the Thermostat, Radiator cap, flushed the coolant ( well it spit 90% of it out lol )
I noticed when it was overheating the reservoir was just being pushed out.
Can it be the Head Gasket?
Please help me out guys.
"Money doesn't sleep, so why should I"
^ the rotary guy who doesn't know anything about pistons lol
Posts: 42 | From: Chicago, IL | Member Since: 09/03/15 | IP: (104.129.196.106) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 1215825 posted 09/03/15 09:06 AM     Remind Me!  Send Private Message   Edit Post
Do the fans run
#1284/2K NB, Totaled
#715/1K KG, Rebuilding
02 Acura TL daily duty unit
12yr+ Vr4 owner.
Honda/Acura master tech.
Family Guy
Posts: 4201 | From: Sioux Falls, SD | Member Since: 07/04/08 | IP: (96.2.247.27) | Report this post to a Moderator
Illinoisinc
Galant VR-4 org Post #: 1215826 posted 09/03/15 09:07 AM     Remind Me!  Send Private Message   Edit Post
Yes the fan is running.
Galant VR-4 org Post #: 1215827 posted 09/03/15 09:16 AM     Remind Me!  Send Private Message   Edit Post
May be head gasket if you are getting pressure pushing out coolant.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10841 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
Illinoisinc
Galant VR-4 org Post #: 1215828 posted 09/03/15 09:20 AM     Remind Me!  Send Private Message   Edit Post
Dammit!!! That is the last thing that I want to do!! lmfao
138/2000
152/1000
Galant VR-4 org Post #: 1215834 posted 09/03/15 10:11 AM     Remind Me!  Send Private Message   Edit Post
head gasket isn't all to hard to do in these cars. find a local who knows what he is doing and you two can have it done in a few hours.
138/2000
152/1000
Posts: 3675 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (50.37.20.150) | Report this post to a Moderator
Illinoisinc
Galant VR-4 org Post #: 1215835 posted 09/03/15 10:17 AM     Remind Me!  Send Private Message   Edit Post
is it really??? Shit.
138/2000
152/1000
Galant VR-4 org Post #: 1215836 posted 09/03/15 10:21 AM     Remind Me!  Send Private Message   Edit Post
yeah. do you have any machine shops by you? id also set it up so you can have the head resurfaced at the shop after you remove the head that or buy a spare head and have that all prepped and ready to go before you start. last time i did one it took me 6 hours and 7 beers.
138/2000
152/1000
Illinoisinc
Galant VR-4 org Post #: 1215840 posted 09/03/15 11:06 AM     Remind Me!  Send Private Message   Edit Post
No I don't know what shops would do it but Ill ask
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 1215843 posted 09/03/15 11:11 AM     Remind Me!  Send Private Message   Edit Post
You've got AMS in that area.......
If the engine is original with over 150k then at a MINIMUM I would replace the valve seals. Finding another head and freshening it up with stock valves, viton seals and maybe a set of Evo beehive springs would extend the life of that engine for another 150k miles and with a set of ARP head studs it's ready for any mods you want to throw at it.
I love my crazy mother!!!
Posts: 1675 | From: Manchester, NH | Member Since: 07/17/06 | IP: (74.94.142.161) | Report this post to a Moderator
Illinoisinc
Galant VR-4 org Post #: 1215844 posted 09/03/15 11:16 AM     Remind Me!  Send Private Message   Edit Post
Yeah they also charge a dick and leg from what I hear lol.
But none the less you are right.
715/1000
1284/2000
Galant VR-4 org Post #: 1215857 posted 09/03/15 12:44 PM     Remind Me!  Send Private Message   Edit Post
Quoting iceman69510:
Not always. If the coolant has a low boiling point then once it boils the expansion rate of the coolant rises. The rad cap opens to release pressure and then the boiling coolant is pushed out the reservoir due to the expansion.
More info on the car would be nice. Once I had a 1g that was overheating. Everything was fine, turned out the owner wired his fans backwards. The air was being pushed to the front of the car.
12yr+ Vr4 owner.
Family Guy
Illinoisinc
Galant VR-4 org Post #: 1215860 posted 09/03/15 12:59 PM     Remind Me!  Send Private Message   Edit Post
It has a 1g motor.
Previous owner stated that it had a new head gasket, rebuilt head. so that I why I am confused.
OldHairyBastard
I take bottom on trannies
1/0000
Galant VR-4 org Post #: 1215863 posted 09/03/15 01:24 PM     Remind Me!  Send Private Message   Edit Post
It can also be the head itself. I've had a motor not blow the head gasket but I did have the aluminum on the head develop tiny holes that would build up pressure in the coolant system and pop radiator hoses. The head gasket was good but cylinder one had the heat damage in the aluminum on the head. If I drove nice everything was fine but hitting boost a few times in a row and POP went a radiator hose. I switched to a new gasket and fresh head and all was right with the Diamond Star Gods. It could also be both.
1990 G-GSX-RS Conversion-138M
1999 Toyota Camry 3.0L V6-210M
2008 Toyota Sequoia 5.7L V8-125M
2013 Toyota Tundra 5.7L V8-107M
2017 VW Passat 1.8L Turbo-45M
2019 Cevy Camaro SS 1LE-5M
Posts: 4500 | From: Lindenhurst, IL-Northern Chica... | Member Since: 04/27/05 | IP: (50.193.72.173) | Report this post to a Moderator
Coltsfan
631/1000
Galant VR-4 org Post #: 1215865 posted 09/03/15 01:28 PM     Remind Me!  Send Private Message   Edit Post
It could also be as simple as a bad radiator cap. The only thing preventing the coolant from boiling when it hits 212F (lower as you go above sea level) is the fact that it's under pressure. I cap that no longer holds pressure, will boil over every time.
Edit: But you have a new radiator cap.
I have a tester that percolates the gas from the cooling system through a blue liquid. If there is CO or CO2 (don't remember which) in the cooling system, the fluid changes to a bright yellow. I would see if you can get someone to test it with that, unless you are 100% sure everything else in the cooling system is up to par, and that the ignition timing is spot on.
When the fan kicks on, do you feel hot air being drawn from the radiator?
92 Galant Vr4 631/1000 ---------DD well on it's way to having new everything...
90 AWD Colt Hatchback ----------Fun car
51 Buick Special ---------------Boring car
Edited by Coltsfan (09/03/15 01:37 PM)
Posts: 200 | From: Tonawanda | Member Since: 05/04/14 | IP: (76.180.2.9) | Report this post to a Moderator
Illinoisinc
Galant VR-4 org Post #: 1215869 posted 09/03/15 02:09 PM     Remind Me!  Send Private Message   Edit Post
I will try that out today. I greatly appreciate it seriously guys. I feel like im a big bother here.
I need to learn these motors quick lmfao
Illinoisinc
Galant VR-4 org Post #: 1215870 posted 09/03/15 02:12 PM     Remind Me!  Send Private Message   Edit Post
Also I just called AMS and was told that they don't work on any DSM's..... That's bogus lol
Galant VR-4 org Post #: 1215873 posted 09/03/15 02:19 PM     Remind Me!  Send Private Message   Edit Post
Tell them it's not a DSM. Truth.
Illinoisinc
Galant VR-4 org Post #: 1215876 posted 09/03/15 02:33 PM     Remind Me!  Send Private Message   Edit Post
I actually said Galant vr4 lol..
G Galant VR4.org Moderator
JDM Unit
486/1000
Galant VR-4 org Post #: 1215888 posted 09/03/15 04:30 PM     Remind Me!  Send Private Message   Edit Post
I would check your timing first.
www.japanesenostalgiccar.com
www.nostalgic.co.jp
Posts: 8896 | From: zompton | Member Since: 02/24/04 | IP: (50.193.76.1) | Report this post to a Moderator
Illinoisinc
Galant VR-4 org Post #: 1215889 posted 09/03/15 04:35 PM     Remind Me!  Send Private Message   Edit Post
What is the timing supposed to be at??
JDM Unit
486/1000
Galant VR-4 org Post #: 1215904 posted 09/03/15 08:46 PM     Remind Me!  Send Private Message   Edit Post
5.
www.nostalgic.co.jp
Posts: 8896 | From: zompton | Member Since: 02/24/04 | IP: (75.86.151.204) | Report this post to a Moderator
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 1215914 posted 09/04/15 07:04 AM     Remind Me!  Send Private Message   Edit Post
btdc
Illinoisinc
Galant VR-4 org Post #: 1215917 posted 09/04/15 08:10 AM     Remind Me!  Send Private Message   Edit Post
BTDC??? what does that mean?
******** UPDATE*******
I took the radiator cap off last night while it was running and you can tell there was a lot of bubbles coming
up from the radiator. I basically did that till it flowing through normal.
Drove it for about an hour and at a red light it started overheating till I would boost and you'll see the temp
drop back to normal ( What the hell lol )
what can that be? is it the head gasket?
Posts: 42 | From: Chicago, IL | Member Since: 09/03/15 | IP: (104.129.196.56) | Report this post to a Moderator
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 1215921 posted 09/04/15 08:21 AM     Remind Me!  Send Private Message   Edit Post
BTDC = before top dead center = advanced. So your base timing should be 5* advanced.
Burping the system is a necessity. If you drove around moving for an hour and the car didn't overheat then it seems fine. If it overheated when you stopped then something is wrong with your cooling fans.
By when you "boosted" do you mean while still at a stop or just when you started driving again?
Pages: 1 | 2
Generated in 0.079 seconds in which 0.05 seconds were spent on a total of 14 queries. Turbo powered.
