WTB: JMF VR4 specific catch can
LIV4PSI
O-H-I-O
Probably a long shot because I assume not many are around. But I would like one and will pay retail. Thanks in advance
BoostedAWD91
Danville,Pa
i sold turbowop the original one that i had made and i know there is one other member that got one but they are the only 2 i know of that were made
this is what he is referring to
LIV4PSI
O-H-I-O
Yep, onesickcrx had the other. He totalled his car though, so who knows where it ended up. JMF doesn't want to make me one /ubbthreads/images/graemlins/frown.gif
LIV4PSI
O-H-I-O
Because they would need my car and it's not driveable. Also, I don't care that much. I didn't realize only 2 were made when I posted this
FlyingEagle
THE Ottawa
Could you make it out of some other material like a cardboard/plastic and ship it to whomever will cut/weld one for you?
Hell even the thick pink foam would do the trick.
then you can marker where you would want mounting tabs and such.
Mockup styles.
ghostinthevr4
Fresno, Califonia
Quoting LIV4PSI:
/ubbthreads/images/graemlins/devil.gif I know what happened to it, a member named IanM purchased it and didn't use it so I purchased it from him it sits on 186/2000 now.
My whole setup is different from what you see here and the catch can is slightly modified.
onesickcrx
NY
Happy to see its being put to good use along with my valve cover /ubbthreads/images/graemlins/cool.gif
89Patches
Ontario Canada
Quoting onesickcrx:
Everything from your old setup is being put to good use! /ubbthreads/images/graemlins/smile.gif
ghostinthevr4
Fresno, Califonia
Did you get the turbo and the manifold from it patches? I wanted to buy that too at the time but I had already purchased a 3065 at the time. Seeing that you and IanM are both from Canada I'm assuming you purchased the turbo and manifold from him.
89Patches
Ontario Canada
Ya when Ian decided to partout the setup after buying mostly everything my brother bought the motor a year prior to me buying #19. When I bought #19 I also bought the rest of the parts off Ian (exhaust manifolds, exhaust etc) Then in turn resold them to my brother which now are in his Evo 3 /ubbthreads/images/graemlins/smile.gif
