WTB: flywheel
Brunoboy
San Bruno,CA Home of SFO
i have a used stock that needs to be cleaned up.
nrvous
Penfield, NY
I have a used 6 bolt Fidanza sitting on a shelf. It went through one clutch failure with a spring bouncing around in there. The result is that the non-clutch mating surface is marred up. I can't seem to measure accurately enough with a set of calipers to make the call on how close it is.
Attached is a picture of the flywheel and you can see the beat up inner surface.
I will sell it for $70.
Worse case, it costs $60 for a replacement surface plate from Summit Racing.
89Mirageman
Stantonsburg, NC
I have one that needs to be resurfaced for $30 and one with a fresh resurface for $50.
