Wiring Harness
centurion882
Mio, Michigan
Need help with replacing a wiring harness, do I need to remove heater fan?? Their is a bolt holding harness a fire wall I can not get to. Any one with info. on this would be greatly aperciated!!!!!! Thanks Dan 989 370 5624
centurion882
Mio, Michigan
Muskrat,when you say removing the lower, what are you referring to?????? The blower motor???? Or do I have to remove everything; blower motor and heatexchanger???? Please respond with more input. Thanks Dan /ubbthreads/images/graemlins/dunno.gif
bustedsm
Ripley, Tennessee
There shouldn't be any bolts holding the harness down, or at least that's my experience with removing the full wiring harness from my DSM. It's just a push type fastener that needs to be popped off /ubbthreads/images/graemlins/laugh.gif
Muskrat
Lexington, KY
It's not sealed, persay, but it is a bitch to get out. I ended up loosening and/or removing (can't remember exactly) the A/C unit (next unit in the line. After that is the heater core, behind the center console). My car didn't have an A/C compressor, so I wasn't worried about venting/leaks from undoing the A/C line though.
moduleunknown
Elk Grove, CA
I just did this yesterday. There is a bolt holding the harness in place behind the blower.
I was unable to remove the blower without first removing the A/C unit next to it.
...one thing I might add (confused me for a minute), besides the A/C lines that need to be disconnected on the back of the unit, there's also a little plastic vent tube a few inches below them that runs out of the back of the unit through the firewall and dumps out under the subframe. That piece just pops off, but I didn't notice it at first and was a little confused as to why I couldn't pull the A/C unit out after unbolting everything (or so I thought). /ubbthreads/images/graemlins/tongue.gif
