It's coming off the harness that hooks up to the alternator. I'm guessing its a ground, but can't seem to find where it would go /ubbthreads/images/graemlins/dunno.gif
Probably the power steering sensor. Locate the power steering pump, look for the male bullet connector (looks like a vac nipple)... if there is not a plug on it, that's probably it. When you're idling, stopped, turning the steering wheel should raise the rpm to help avoid a stall condition. If it doesn't go up, this is the reason.
