whistling noise from intake
at idle a whistling noise comes from the intake< dose this mean i might have a blown turbo? i have no leaks in my intake, the intake is completely covered, suggestions?
mikus
Aurora IL
what did it do before? Ie, is this the same parts and and a new noise, or did any parts change (and which ones)
the car will hold boost just fine, and i just bought the car so i really have no clue whats new and whats not.
curtis
Clarksville TN
Pull the inlet tube off and check for shaft play on the turbo. If I had to beat its time for a new turdo. Mine died a painful death after numerious passes at the track, my first visit with the car, that was a bad sign of things to come. Thing was it held 15psi fine just would smoke after a few times into boost. Drove it like that for a few weeks until the scream was ticking me off. The scream was the wheels eating into the housings.
johnnyRacer
Tampa, FL.
Quoting Brianawd:
Does it sound like this
That ain't right, man. /ubbthreads/images/graemlins/rofl.gif /ubbthreads/images/graemlins/dunno.gif /ubbthreads/images/graemlins/devil.gif
galant344
oakforest il.
where in chicago are you located? could be a bad turbo like everyone says could also be a fairly large leak. last year i had a large leak and the car would still boost well but make a horrible noise as well
14bCrazy
Virginia
Mine does this but only when I let off the gas /ubbthreads/images/graemlins/dunno.gif
CP
West Simsbury, CT
A crushed stock BPV will make a high-pitched whistle at partial throttle. Mine did it around 3K rpm with zero boost.
the whistling went away randomly it must be the way i had the intake postioned i need to put dejon intake on
1990ggsxnj
Blackwood, NJ
LOL Yes, you always must upgrade!! I look for any excuse anyways /ubbthreads/images/graemlins/grin.gif
Good to hear it stopped.
