wheel bearings / hubs
Spyder
Des Moines, Iowa
I need to do the wheel bearings on my car. I have been looking for parts and fond this at rockauto. I assume it is the rear hub? web page
Can you get the front hub assembly with bearings anywhere?
pot
Fayetteville, NC
I just did my passenger front wheel bearing using parts from Autozone. I paid about $75.00 total for the inner/outer seal and wheel bearing itself with a 1 year warranty. I didn't see the need for a new snap ring which is in the JNZ kit however in hindsight I wouldn't mind paying more for factory Mitsubishi parts.
I've never seen the hub assembly with bearing offered for the galant/1g unlike the 2g, which is a sealed unit.
slugsgomoo
Tacoma, WA
some places will list a unit like that rock auto one for the rear, but it's the wrong part, just listed for AWD by systems that don't work right.
The kit to do the rears from JNZ is the cheapest around and has everything you need. I did mine in the 1g before I found their kit and ended up spending significantly more to get all the seals & bearings.
