What is the best gear ratio Transmission for 4g63t?
EHmotorsports
Beaverton
You can also do 91-92 1st and 2nd gears with 92-99 3/4 gears for a stronger unit. It just won't be a super close ratio like the EVO gear set.
Edit: correction the 1st and 2nd gear need to be 93-99 and 3/4 are 91-92. thank you donniekak
donniekak
surprise az
Quoting EHmotorsports:
You have it backwards. The 93-99 2nd gear is used because it's a double synchro, and the small synchro 3-4 91-92 setup is used to prevent the large synchro 93-99 3-4 slider from exploding. All the major trans builders use this as their hd setup. You won't see a 3 hole 3-4 shift fork in any of the hd transmissions.
EHmotorsports
Beaverton
Ahh yes thank you for the correction. I just swapped gearsets from two transmission and transposed the years.
